Telescoping Wand For Power Washer - Painting - DIY Chatroom Home Improvement Forum
Old 05-17-2014, 06:24 PM   #1
Painting Contractor CT
Rewards Points: 77
Post
Telescoping Wand for power washer
Hi All,
Looking to purchase a telescoping wand, any suggestions as far as length, material go? Was debating between an 18ft and 24ft wand in fiberglass. What do you guys use for washing homes prior to painting?
Really appreciate any feedback on this.
KD PAINTING is offline   Reply With Quote
Old 05-17-2014, 08:00 PM   #2
Rewards Points: 6,034
The one I have is 18' but I think it's steel.
The Following User Says Thank You to ToolSeeker For This Useful Post:
KD PAINTING (05-20-2014)
Old 05-18-2014, 03:53 PM   #3
Rewards Points: 4,796
I have a long one from Northern Tool, but I don't use it much any more since I figured out how to really wash a house - with soaping tips. You might want to check out a good pressure washing forum for more info. Those telescoping wands can be really really hard to manage when they get fully extended. That pressure has a whole lot of leverage on you at that length - hard to control and difficult on your body.
jeffnc is offline   Reply With Quote
The Following 2 Users Say Thank You to jeffnc For This Useful Post:
Gymschu (05-18-2014), KD PAINTING (05-20-2014)
Old 05-18-2014, 06:10 PM   #4
Gymschu's Avatar
Rewards Points: 1,020
Boy are you right about that, Jeff! I have an 18 footer as well, aluminum I believe. It's great for about 12 of those 18 feet, but, once it's fully extended, it makes a man out of you in a hurry. Plus, I find it hard to see if I'm actually getting the surface clean being so far from the surface. I rarely use it.
The Following User Says Thank You to Gymschu For This Useful Post:
Vibration In High Speed Spin Mode Davy49 Appliances 7 12-30-2014 09:47 AM
Under counter washer / dryer installation wstt Plumbing 0 04-10-2012 11:00 AM
bolt that holds the tank to the toilet bowl is leaking andrewjs18 Plumbing 13 04-06-2012 10:43 AM
Washer & Dryer Holiday Fun BRIANisMEisWE Appliances 8 12-24-2011 02:41 AM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
