Old 05-29-2011, 11:12 PM   #1
Taping already painted wall trouble!
I'm painting two walls two different colors, and they're meeting in the corner. I painted the darker wall already, I need to tape to do the lighter color wall....how long do I need to let the dark wall dry before I put tape on it (blue tape)?
Hoping for an answer as soon as possible!
loretta_ is offline   Reply With Quote
Old 05-29-2011, 11:34 PM   #2
Gymschu's Avatar
Tough one to answer because different kinds of paint dry differently. I like to wait at least 72 hours before doing any masking. What you can do is buy a great cut-in brush and just cut a nice straight line right down the wall in the corner with your other color. Yes, it takes a steady hand and some patience, but it is very doable and you won't have to wait 2 or 3 days.
Gymschu is online now   Reply With Quote
Old 05-29-2011, 11:34 PM   #3
Rubbin walls since'79
Brushjockey's Avatar
Use orange core blue ( sensitive) - not all blue is the same. What paint?
usually a couple of hours, lightly put on the blue, paint the edge with the first color, let that dry a bit ( that makes any bleed happen with the same color) and then finish. A fan on it will also speed things up.
72 hrs is a DIY wait- and thats not a bad thing. As a pro I don't have 72 hrs, so i find a way.
Brushjockey is online now   Reply With Quote
Old 05-29-2011, 11:49 PM   #4
ltd
get some low tack mask tape 1/2 inch press in to corner make contack but dont press to hard .i have done it in a little as 2 hours . but if you wait till next day you'll be golden
ltd is online now   Reply With Quote
Old 05-30-2011, 01:46 AM   #5
Thank you all!!! I am using Olympic paint, eggshell finish. And the tape I have is Scotch 3M Blue Painter's Tape;original multi-surface. I do not want to wait 72 hrs. I may use a fan to speed up the process or (if I haven't fallen to pieces by then) use the cutter brush to do the straight line. Thanks again :-)
Old 05-30-2011, 07:14 AM   #6
Loretta, if you choose to go freehand, it's really not as hard as you might think. I have an online tutorial with tips that may be of some help. Good Luck.
Go to my painting guide and look for the link on the right, painting without tape.
Old 05-30-2011, 07:16 AM   #7
paper hanger and painter
chrisn's Avatar
That is the wrong tape to use here, you really need the sensitive orange core blue tape.
chrisn is online now   Reply With Quote
The Following User Says Thank You to chrisn For This Useful Post:
loretta_ (05-30-2011)
Old 05-30-2011, 07:30 AM   #8
Thank you Chrisn I was looking for the "correct" tape.
Old 05-30-2011, 11:45 AM   #9
sdsester's Avatar
The new frog tape is nice too. You will be surprised at the line you can achieve with a nice quality 2.5 or 3 inch angled sash brush though.
The tape Chris mentions will work but I would be nervous putting it on to quickly on a surface painted eggshell with something like Olympic.
If you are uncertain of your painting skills a nice long straight edge you can use as a masking tool would work too since our concern is a right angle corner? Nice long drywall knife or something should work? Just wipe it off between brush strokes.
sdsester is online now   Reply With Quote
The Following User Says Thank You to sdsester For This Useful Post:
drtbk4ever (05-30-2011)
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 09:22 AM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Recently painted bathroom wall paint cracking hansmike Painting 9 02-01-2010 09:55 PM
Temporary wall support question discojv Building & Construction 7 01-25-2009 08:23 PM
