#1 |
Tank will not build up more than 40lbs!
I bought a CH vertical WL6700 series compressor about six months ago. It worked ok for a while, but recently, it will only build up pressujre to a max of 40lbs. I checked all the air lines; no leaks. I thought it may be the check valve, so i replaced it. With the new check valve, it would build no pressure at all. I removed the large spring from the check valve; you (still) get good air in the spray hose, but no more than 40lbs in the tank. I'm about to pitch this thing if i can't figure out what is wrong. When new, it would build to about 120lbs. I also checked the belt (it's new). If you blow into the check valve with the primary button depressed, air will go out the spray hose outlet no problem. You only get about 33% or air coming out the inlet that fills the tank. I can't belive i could have two faulty check valves in a row, so i must be missing something. BTW, when the pump is running, i can barely hold my thumb on the outlet from the pump - so the output from pump seems strong. HELP!
#2 |
Rubbin walls since'79
You might do better on the carpenter forum- very few painters use a conventional spray set up with regular air compressors anymore.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS |
#3 | |
jschaben
Tank will not build up more than 40lbs!Quote:
Does it build to 40 lbs and shut off or get to 40 and keep running but not get any higher?
John Schaben "Where all think alike, no one is thinking very much" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#4 |
You have bled the tank?
#5 |
I've never seen a compressor with a check valve, are you sure your not messing with the pressure regulator or the safty pop off?
Several times when I had the problum your having it's the line from the tank to the pressure regulater that's came off or has a hole in it. (some have no line and are connected directly to the tank) |
| Display Modes | |
| Repair 1962 Rheem pink toilet tank or find vintage replacement ? | khaef | Plumbing | 0 | 09-09-2011 10:55 AM |
| Working with acrylic for fish tank build | robrich342 | Tools | 12 | 03-16-2011 04:39 PM |
| All problems have a solution (septic tank resolutions) | Snav | Plumbing | 3 | 04-23-2010 10:11 AM |
| Relocating Oil Tank | jbboater | HVAC | 2 | 03-23-2008 08:50 AM |
