Taking Off Door Hinges - Painting - DIY Chatroom Home Improvement Forum
Old 03-31-2014, 05:11 PM   #1
Rewards Points: 18
Taking off door hinges
Hi..If you were to take off your doors and spray them somewhere other than in place what do you do about the hardware like hinges and doorknobs? I was thinking of using an hvlp on the trim. Would the answer be different if I brushed the door casing instead of hvlp? Thanks.
Nimnum is offline   Reply With Quote
Old 03-31-2014, 05:15 PM   #2
Rewards Points: 6,652
Most people that paint a door, remove all hardware off of them.
Old 03-31-2014, 05:35 PM   #3
Rewards Points: 13,282
No matter how you paint them you should remove the hardware.
No way would I try and spray paint trim that's installed.
Going to spend way to much time masking, cleaning the gun, redoing all the paint that gets pulled off when you remove the tape.
Old 03-31-2014, 06:15 PM   #4
Rewards Points: 5,974
Although I don't necessarily agree with some of what Joe said yes remove the hardware. Another tip if you remove more than 1 door at a time number them so they go back in the same hole.
Help Taking down this dryall is a bi$&? Mstrlucky74 Drywall & Plaster 4 11-02-2013 11:47 PM
Incompetent Contractor taking advantage ? (pictures) ford361 Kitchen & Bath Remodeling 11 06-21-2012 07:42 AM
Changing Kitchen Flooring from tile to Hardwood? Regarding taking cabinets up? doodleb1973 Flooring 3 07-27-2011 06:25 AM
invasive grass taking over Kentucky bluegrass annie68164 Landscaping & Lawn Care 18 04-07-2011 05:19 AM
Enclosed Patio taking up water profenx Building & Construction 0 10-12-2010 02:20 AM
