-   -   This is taking a LOT of paint... (http://www.diychatroom.com/f4/taking-lot-paint-120210/)
clashley 10-15-2011 03:29 PM
I start painting on the nursery this week. I'm using a satin latex, and applying with a 9" roller with 3/8 nap. This is being applied over drywall covered with an eggshell latex.
I've got two coats on one wall completed, which is about 90 square feet. The coats went on easy enough (about 48 hours between the first and second coat), and I've got nice good coverage and even color after the second coat.
My only concern is that this took about 2/3 of a gallon of paint. My last painting project was nearly identical... I painted an adjacent bedroom with satin latex using a 9" roller with 3/8 nap and covered the same eggshell paint. That project was a lot more economical on paint. If I used 2/3 a gallon of paint to put two coats on a 90 square foot wall, that means I'm getting 270 square feet/gallon on this latest project.
Am I using the wrong roller? That's the only thing I can think of... When I finished the first coat, it looked pretty typical (decent coverage, but obvious that a second coat was needed). Maybe my expectations are unrealistic, but I was thinking I should be getting at least 350 sq ft/gallon.
Thoughts?
chrisn 10-15-2011 04:39 PM
1 Attachment(s)
I do not want to open a can of worms, but what paint are you using?
clashley 10-15-2011 04:51 PM
I'm using Valspar Ultra Premium satin finish: http://www.valsparpaint.com/en/find-...a-premium.html
This is the same stuff I used to paint my daughter's bedroom (the previous project that I described) last year and I had no problems/complaints with it, so I bought it again. Maybe that wasn't a good idea?
The total wall space in the nursery is right around 400 sq feet (subtracting for doorways and windows), so I figured 2 gallons would do it. Based on the coverage rate I got on the first wall, I'm starting to think that I am doing something wrong.
I've never had to do this before on painted walls, but should I put primer over the eggshell on the remaining walls before I proceed? It would be some extra work, but a gallon of primer is lot cheaper than another gallon of the satin latex.
jschaben 10-15-2011 05:25 PM
What does the can say the coverage should be? Most I have looked at lately say 250 - 400 sq ft/gal. I usually take the lowest number for the first coat and highest number for the second coat to figure quantity needed. 270 is right in the ballpark for a first coat.
clashley 10-15-2011 05:59 PM
The can simply says "up to 400 sq ft." If the 270# is a realistic value, then I can live with it. I was just surprised because this was a bit different than my previous experience.
jschaben 10-15-2011 07:14 PM
I dunno, I've been taking those numbers on the cans as pretty optimistic lately. I've got some Benjamin Moore thats 15 years old and the can says 300 to 500 sq ft/ gal and, by golly, was able to get every bit of that. I used the min/max formula to compute what paint I needed and had 3 gallons left over on my house. I just switched to Sherwin Williams procoat for some cabinets and it says 250 - 400 sq ft per gallon and after the first batch of cabinets I figure I'll be lucky to get the 250. I'm thinkin the "up to 400 sq ft" means you're d*** sure not gonna get any more out of it.
Gymschu 10-15-2011 07:51 PM
There have been times in my 35 years of painting that I have had the problem you describe clashley. Usually I attribute it to the roller cover. Most of the time I use Wooster or Purdy roller covers but every so often I buy an off brand. What would be wrong with that, you say? Well, believe it or not, some covers soak up paint differently and then don't lay the paint on the wall quite as efficiently. By that I mean that more paint seems to stay soaked up into the cover rather than releasing onto the wall. I can't explain it, it really doesn't make a lot of sense, but, I have had it happen. Now, I just stick with Wooster roller covers, I know the nuances of using them & I get the same consistent coverage each and every time I paint.
clashley 10-15-2011 07:57 PM
Funny you should mention that... I did some digging in my workshop (because I never take out the trash).... my last project was done with Purdy roller covers.... this time, I'm using Wooster.
Aside from the advice here, I've also spoke with a couple of friends in town and the general consensus seems to be nothing is wrong, I just probably need some more paint.
Now that I feel better, it's time for beer and football :)
chrisn 10-16-2011 04:13 AM
Now you got it. Most likely was just the difference in the covers, as gym said they are all slightly different. Next time ty a 1/2 inch, it will apply much easier:yes:
mustangmike3789 10-16-2011 03:53 PM
400 sq.ft/gal @ what mils??? This paint is 36% solids, so it should cover 577 sq.ft/gal @ 1 mil dry film thickness (dft). The 400 sq.ft/gal quoted on the can is @ 1.5 mil dft. Im going to have to say that applying this paint with a 3/8" nap full strength without thinner would be around 2 mils without factoring in any waste. A gallon of 100% solids paint will cover 1604 sf.ft @ 1 mil dft. 1604 x .36 = 577 sqft/gal. 577 / 2 mils = 288 sq.ft/gal - 10% waste = 259 sq.ft/gal. If you are getting 270 sq.ft out of a can then you are right where you need to be for each coat.
jsheridan 10-16-2011 05:11 PM
Yeah!! That's right.:laughing: That's the ticket.
You stole my thunder Mustang:laughing::laughing::laughing::laughing::la ughing::laughing::laughing::laughing::laughing:
Where you been? You're the tech guy, we need you.
mustangmike3789 10-16-2011 05:38 PM
Thanks Joe. I took a little vacation to Hawaii for a few weeks. Now I'm back to the grind again.
