Tacky Paint - Painting - DIY Chatroom Home Improvement Forum
Old 07-30-2010, 10:07 PM   #1
vap
Post
Tacky Paint
My husband and I are helping our son remodel his bathroom. He has an older (60 year old) home. We stripped off multiple layers of paint, and fixed some bad spots on the wall. Then we primed the bathroom walls with 2 coats of Zinsser primer. Then we painted the lower half of the walls with a dark brown latex semi-gloss Valspar paint and we painted the upper half of the walls with a light beige latex semi-gloss Valspar paint. After 5-6 hours the beige paint dried perfectly. But it has been over 24 hours and the dark brown paint is still tacky to the touch.
We absolutely have no idea why the lower half, painted with the dark brown Valspar is not drying. These walls were all stripped and primed exactly alike.
Right now we have fans blowing on the walls in the hopes of assisting the drying process.
Anyone have any idea's why this happens; and what can we do to fix the problem?
Appreciate any suggestions.
vap is offline   Reply With Quote
Old 07-31-2010, 03:50 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 616
What you are doing should work, sometimes dark pigmented paints take longer to dry.
chrisn is online now   Reply With Quote
Old 08-01-2010, 02:28 AM   #3
Faron79's Avatar
Rewards Points: 260
The colorant load is the key...
Yep...deep colors have 20-30 times the colorant-load relative to lighter colors!
This translates into waaaaayyyy longer "cure times" for deep colors.
Sorry, but this will persist for some time yet! Could even be a month+...
Keep using fans, and keep the A/C on to lower humidity, especially if it's hot/humid outside.
Air-exchanges are the key.
Faron
Faron79 is offline   Reply With Quote
Old 08-01-2010, 07:39 AM   #4
Rewards Points: 272
Same thing happened for me. I painted the lower half of my walls white and the upper half cherrokee rust. Took the rust color way longer to lose it's tackiness compared to the white.
speedster1 is offline   Reply With Quote
Old 08-24-2010, 11:07 AM   #5
tacky paint
I have a similiar problem. Had my bathroom painted over 3 weeks ago with a good quality Sherwin Williams semi gloss latex. It was primed and dried for two days before applying the paint. Still is tacky! Does anyone have an answer or what to do to take off and start over?
nancywells is offline   Reply With Quote
Old 08-24-2010, 11:38 AM   #6
Where are you located ?
What has the humidity level been ?
What color paint ?
Old 08-24-2010, 11:41 AM   #7
(the original)
Rewards Points: 756
And to add to Dave's questions, Are you using the bathroom daily? Does it have an exhaust fan?
ratherbefishin' is offline   Reply With Quote
Old 08-25-2010, 10:34 AM   #8
San Diego, mild levels of humidity, mid range green color. Thanks
Tacky, black...death? rikkijustmike Flooring 13 03-25-2011 12:32 PM
Cabinet paint still tacky after a week.... tigereye Painting 7 09-05-2009 04:29 AM
Help! Sticky, tacky deck stain rainytown Painting 5 10-22-2008 03:57 PM
