Old 03-18-2013, 04:11 PM   #1
Swingset waterseal
Just ordered a cedar swingset for the little ones, and was hoping someone could recommend a long lasting sealer for it. I'm planning on treating the boards before we put it together. We're in the midwest, and it will be in full sun/winter elements.
Many thanks!
Leanne1 is offline   Reply With Quote
Old 03-18-2013, 04:43 PM   #2
Swingset waterseal
http://www.cabotstain.com/products/p...and-Fence.html
Old 03-18-2013, 04:45 PM   #3
cdaniels's Avatar
Swingset waterseal
Sherwin Williams Woodscapes.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
The Following User Says Thank You to cdaniels For This Useful Post:
Gymschu (03-18-2013)
Old 03-18-2013, 07:50 PM   #4
Swingset waterseal
Clear or toner, or solid stain?
Old 03-18-2013, 08:48 PM   #5
Gymschu's Avatar
Swingset waterseal
All good suggestions so far. I also like CWF-UV made by the Flood Co. It's a reasonably priced clear sealer or you can buy the cedar or redwood tones for a bit of color. On something like a swing set you should get at least 3 or 4 years of protection before recoating.
The Following User Says Thank You to Gymschu For This Useful Post:
cdaniels (03-18-2013)
Old 03-18-2013, 10:39 PM   #6
cdaniels's Avatar
Swingset waterseal
Flood makes good products.You won't go wrong there either.
Gymschu (03-19-2013)
Old 03-19-2013, 11:57 AM   #7
Painting Company, NY
housepaintingny's Avatar
Swingset waterseal
Sikkens Cetol 1
housepaintingny is offline   Reply With Quote
Old 03-26-2013, 09:01 PM   #8
Swingset waterseal
Thank you for all of the recommendations! It snowed about a foot here over the weekend, so now I just need for this weather to cooperate!
Thanks again!
Leanne
Old 03-26-2013, 09:23 PM   #9
Swingset waterseal
Clear would be ideal, and I'd rather stay away from a solid stain. I'm not sure what a toner is....
Old 03-26-2013, 09:35 PM   #10
Gymschu's Avatar
Swingset waterseal
Toner just has a little bit of color in it. For example, CWF-UV comes in Clear, Cedar (toner), or Redwood (toner). All three are basically clears but the Cedar and Redwood have just enough color (toner) to give the finished product that orange hue (for Cedar), or a Reddish hue (for Redwood).
asymetrical sister to bending swingset beam?? bergerdude Building & Construction 4 05-02-2012 03:58 PM
beef up swingset beam? D270 Building & Construction 3 04-16-2012 02:52 PM
"T" Frame Swingset dcd22 Carpentry 1 11-21-2011 01:08 PM
Swingset Plans/ Kit organick Building & Construction 10 01-07-2011 08:03 PM
Waterseal poured foundation ktwags Remodeling 4 04-24-2007 09:39 AM
