Old 09-25-2009, 04:46 PM   #1
Question
SW Duration over Superpaint?
So for repainting my house a while back I bought a bunch of Sherwin Williams exterior latex Superpaint that was on sale, and also a gallon of exterior latex Duration, both satin finish. My question is I have used up most of my Superpaint yet still have this gallon of Duration, can I apply the Duration over a single coat of Superpaint? If its ok do I need to sand the first coat to rough it up a bit for the Duration to adhere or is sanding overkill?
Thanks.
creamaster is offline   Reply With Quote
Old 09-25-2009, 06:37 PM   #2
paper hanger and painter
chrisn's Avatar
You should be fine, no sanding necessary.
Old 09-25-2009, 06:39 PM   #3
Painting Company, NY
housepaintingny's Avatar
Thanks.
You will be perfectly ok applying the duration over the superpaint, there is no sanding needed. They are both waterbourne(acrylic). My personal preference between the two is SuperPaint. We use that on all of our exterior painting and our work is warranted in writing. I have tried Duration, but am still a SuperPaint fan, I feel that a primer is a primer and a paint is a paint and that the two should not be mixed in the same can.
housepaintingny is offline   Reply With Quote
SW Duration vs. Cashmere jerryh3 Painting 3 03-26-2009 08:47 PM
SW Duration Home interior problems marathon851 Painting 9 10-10-2007 12:04 AM
Exterior Paint: Duration, Superpaint, Manor Hall, or Timeless? mwewriter Painting 5 08-15-2007 07:05 AM
Differences between SW Duration, Superpaint and Cashmere? Autumnknight Painting 2 03-08-2007 09:55 PM
