SW Bathroom Paint - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-24-2013, 05:10 PM   #16
Rubbin walls since'79
Brushjockey's Avatar
Pay attention to what has been said? Just a thought..
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
jsheridan (03-24-2013)
Old 03-24-2013, 11:03 PM   #17
Rewards Points: 2,072
Yes, BJ, I read what has been said here. I prefer not to have to mix my own 'mildewcide' nor do I want to use a regular paint.
I'm disappointed as I've had great success with SW paint. I don't know anything about BM paint but I'll research it.
Startingover is offline   Reply With Quote
Old 03-24-2013, 11:09 PM   #18
The "bath " paints are either formulated to be low sheen ( like BM Aura B+ K) , but not needed in the eggshell and up sheens, or they have the mildicide.
Almost all eggshells will work very well.
It is the sealed surface to moisture that is most important.
But if you need the can to say Bath- go find it.
Startingover (03-28-2013)
Old 03-24-2013, 11:15 PM   #19
cdaniels's Avatar
Zinsser Perma-White is moisture resistant and is called "mildew proof"Check it out it may be just what you're looking for and all the box stores carry it.At least the ones around here do.Don't let the name fool you, it can be tinted.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
The Following User Says Thank You to cdaniels For This Useful Post:
Old 03-24-2013, 11:25 PM   #20
Starting has had this said Many times..
Old 03-24-2013, 11:34 PM   #21
thanks Cdaniels.
I appreciate the info. I had colors selected at SW and thought I'd walk in and get what I wanted with no problem. Besides, SW gave me a contractors discount since I was doing a whole house and that has been nice.
I like HD also, so will look at their colors this week.
BJ, "many times" interesting. Twice, when I inquired about ceiling paint. But, I guess twice could be called 'many'.
Old 03-25-2013, 08:36 AM   #22
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
now, now, be nice
The Following User Says Thank You to chrisn For This Useful Post:
Startingover (03-25-2013)
Old 03-25-2013, 08:39 AM   #23
chrisn's Avatar
Rewards Points: 228
start. If you have to have SW, get a packet of mildewcide and mix it in a gal of satin, or eggshell paint( have them do it), done, problem solved, move on.
The Following 2 Users Say Thank You to chrisn For This Useful Post:
cdaniels (03-25-2013), Startingover (03-28-2013)
Old 03-27-2013, 05:50 PM   #24
Originally Posted by Startingover View Post
Went to S.W. for bathroom paint for walls. They have a sale going on and were too busy so I left and will go back another time.
In case someone new waits on me, I want to be sure I get the right paint.
Does anyone know the name of the moisture barrier paint at S.W.
thank you.
I work at Sherwin Williams, and best bet for kitchen, baths, and active homes (kids) is Duration. It has a moisture barrier in the paint and low VOC. The suggested paints are discontinued, and mixing paint is not recommended. Right now, most of the stores have Duration on sale, if not, it probably just ended and will start again next month. Only other real option would be Emerald. All paints are NOT the same. Manufactures use additives in the paint for desired effects like moisture barriers. Duration will be washable after 30 days as well.
The ceiling paint we currently sell is Eminence. If this is your bathroom, I would still suggest Duration because of the moisture barrier. Remember, heat rises and all of the steam will be directly on that area.
dispense05 is offline   Reply With Quote
The Following 3 Users Say Thank You to dispense05 For This Useful Post:
Gymschu (03-27-2013), Startingover (03-28-2013), ToolSeeker (03-28-2013)
Old 03-27-2013, 06:46 PM   #25
Actually S-W does still make Bath paint. not only is it on S-W's website but it is also in their system. I went to another store who found a store that carried it and put in an order for me that will be on their next truck.
toastandjam is offline   Reply With Quote
The Following User Says Thank You to toastandjam For This Useful Post:
Old 03-28-2013, 05:18 PM   #26
Good information. Thank you all.
This has been the hardest decision. The problem with the first recommended Zinsser Perma White was that I read reviews saying it couldn't be tinted to a dark color, which is what I planned.........to match one shower curtain.
Reading reviews on BM Aura, I read a lot about "streaking". But then one SW review said there were lumps in Duration. Another main concern, is chemicals which I try to avoid because the person using this bathroom the most has allergies. That's what's holding me back from adding mildecide.
This is a guest bath, but guests often stay 2 weeks at a time, so it gets more use than many guest baths. Also this is Florida so mildew is more of a concern here.
My Zinsser 'Gardz' arrived and my walls are now primed. One review warned how runny it was and how badly it splatted everything rolling it. With that in mind, I cautiously brushed a few strokes to test. It went so smoothly with a brush that I felt better able to control the splatters and runs, so brushed all the walls.
After all the information and research I'm leaning towards just using a semi gloss.
Old 03-28-2013, 05:58 PM   #27
Rewards Points: 5,974
Hey schu where in Ohio I'm from Youngstown, East Liverpool area.
Old 03-28-2013, 07:07 PM   #28
cdaniels's Avatar
That will be fine but a semi is too much sheen on ceilings for my taste (just my humble opinion).Carry on.
Old 04-01-2013, 01:39 PM   #29
Rewards Points: 626
Harmony from SW eliminates the VOC's and odors for up to five years. Great for bath rooms and kitchens.
Nailbags is offline   Reply With Quote
The Following User Says Thank You to Nailbags For This Useful Post:
Startingover (04-02-2013)
Old 04-01-2013, 05:39 PM   #30
Gymschu's Avatar
Rewards Points: 466
Toolseeker, south of Canton Ohio........New Philadelphia.
Gymschu is online now   Reply With Quote
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
alligator cracking lead based paint in bathroom protechplumbing Painting 10 09-02-2013 01:15 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
Questions about Sherwin Williams paint for a bathroom nitting Painting 2 03-28-2011 05:23 PM
Bathroom paint dilema JamesTee Painting 8 02-03-2011 09:46 AM
