Susanjane - Painting - DIY Chatroom Home Improvement Forum
Old 05-18-2012, 08:36 AM   #1
susanjane
What is the best paint product to cover cat urine?
susanjane5555 is offline   Reply With Quote
Old 05-18-2012, 09:03 AM   #2
Rubbin walls since'79
Brushjockey's Avatar
The most used sealer for difficult stains and smell is alcohol based pigmented shellac- called BIN.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 05-18-2012, 11:11 AM   #3
Too Short? Cut it Again!
You should probably first try treating the areas with an enzymatic formula available at the pet store or some janitorial suppliers. Nature's Miracle is one just product but there are others. Then prime and seal with something like BIN.
If drywall has become saturated you will have to cut out and replace the damaged areas.
The Following User Says Thank You to user1007 For This Useful Post:
Ravenworks (05-18-2012)
Old 05-18-2012, 04:42 PM   #4
Mr. Paint's Avatar
Susan:
SDester is right on the money. Another 'smell-killer' is Bio-Zapp. This product works wonders. Zinsser BIN is a pigmented shellac that you will need denatured alcohol for clean-up. I had a cat that ruined a floor so bad I had to have several boards replaced and the floor refinished.
http://www.biozapp.com/products.html
Mr. Paint is offline   Reply With Quote
