Suggestions On Stain For Fence - Painting - DIY Chatroom Home Improvement Forum
Old 06-27-2010, 09:43 AM   #1
Rewards Points: 159
Suggestions on stain for fence
I have a cedar/PT picket fence I put up last fall.
300 feet worth
I want to make it as white as possible.
Would prefer to stain it.
Spray would be good also.
I have an air compressor and a HLVP gun, but the canister on top is rather small, I think I will spend a lot of time filling this.
I am looking for suggestions on sprayer, brand and type of stain.
I would like it to be white - do not want to paint due to future maintainence.
theedudenator is online now   Reply With Quote
Old 06-27-2010, 10:20 AM   #2
Sikkens, Cabot's Pro VT, BM Arborcoat, PPG Sun Proof and SW Woodscapes are all quality solid color acrylic stains and I think most are self priming.
Forget your HVLP gun. Just rent a professional airless sprayer at the store where you buy the paint. They'll also need to fix you up with the right size tip for the coating and spray pattern.
I'd spray and then backbrush for best results.
hennyh is offline   Reply With Quote
Old 06-27-2010, 12:08 PM   #3
Rewards Points: 159
I was thinking I was going to use oil based. Is there a reason why I shouldn't?
Old 06-27-2010, 11:01 PM   #4
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
I would go with the Cabot ProVt and apply it with an airless sprayer, back rolling and brushing as needed on the first coat and then just spraying on a second coat That is my choice of solid stains and I do prefer acrylic for solid stains to use on verticle substrates. We use the ProVt often followed by SW Woodscapes.
housepaintingny is offline   Reply With Quote
Old 06-27-2010, 11:29 PM   #5
Matthewt1970's Avatar
Rewards Points: 1,098
Oil is fine. It would be my first choice. It is much les likely to peel.
Best stain for cedar siding pgreef Painting 17 07-08-2011 10:43 AM
Fixing a screwup - stain on oak plywood brich Carpentry 9 05-13-2010 11:09 PM
Looking for suggestions on kitchen cabinet stain color.....pictures attached Rhizzlebop Interior Decorating 15 04-05-2010 02:43 PM
Need advice on removing deck stain mwalt2 Painting 7 07-23-2008 05:51 AM
