Suggestions For Primer In Bathroom - Painting - DIY Chatroom Home Improvement Forum
Old 06-15-2012, 04:22 PM   #1
Suggestions for primer in bathroom
Hello! I'm a noob, both to this site and to the world of DIY house stuff. So this is probably a clueless question, but I am very eager to learn.
Recently purchased a 100 year old rowhouse that is completely covered in rather heinous wallpaper. I am gradually stripping the paper, doing minor patching of the plaster underneath, and repainting. The plaster has never been painted before.
My question is about the bathroom. It doesn't have a fan, and although it doesn't get extremely humid in there, I still want to make sure I avoid peeling paint in a few months or years. I'll be painting on raw plaster, and want to ask for some advice about what kind of primer is best to use in there. I have shellac primer, for no other reason than that my mom got some for me. Would this work well for the job in a bathroom? Or should I use some other kind of primer?
I've read that the top coat should be semi-gloss, as a matte or satin finish is more likely to peel.
I appreciate any advice you all might offer.
Emthestrange is offline   Reply With Quote
Old 06-15-2012, 04:38 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
After stripping _ and getting as much paste off as you can!- you need to seal back any paste residue before painting. If you have the pigmented shellac- usually a product called BIN- it will work but it is nasty to work with.
My favorite is called Gardz- a clear waterbase sealer. A good oil primer will also work.
Then you can repair- spot prime those and finish with a good quality eggshell or better sheen - and you will be good to go.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
Emthestrange (06-15-2012)
Old 06-15-2012, 04:50 PM   #3
Thanks so much for your advice! The stuff I have is BIN Shellac based primer. (Yes, it stinks to high heaven.) So I think I will go ahead and use that, though I will get some Gardz for future projects.
Old 06-15-2012, 05:03 PM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 394
Matte or satin or eggshell will not peel anymore than a semi gloss, bad information there. I would go with an eggshell or satin finish, semi gloss on walls looks like a hospital to me, bad memories
Old 06-15-2012, 05:26 PM   #5
Thanks, chrisn. This is why I joined the site; too much misleading information out there on the internet.
Old 06-15-2012, 10:24 PM   #6
(the original)
Rewards Points: 756
I've recently seen a few cases of BIN alligatoring after a couple years in unventilated bathrooms. I don't recall ever seeing that problem before I came to the Gulf coast, so it might be climate specific. I'd play it safe and use an acrylic, like Gardz or Bullseye 123. Think about adding an exhaust fan, too.
ratherbefishin' is offline   Reply With Quote
Old 06-16-2012, 03:13 AM   #7
chrisn's Avatar
Rewards Points: 394
I agree
Old 06-16-2012, 08:21 AM   #8
Matthewt1970's Avatar
Rewards Points: 1,098
NO, 123 is not sufficent if there is any chance of wallpaper glue getting left behind. Especially in a bathroom.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 06-16-2012, 10:33 AM   #9
(the original)
Rewards Points: 756
You're right, I missed the wallpaper part. Stick with Gardz. Thanks.
Old 06-16-2012, 05:55 PM   #10
chrisn's Avatar
Rewards Points: 394
I missed that also
Old 06-17-2012, 12:06 PM   #11
Thanks, all, for this suggestion. I'm in central PA, which doesn't get crazy humid. But I think I'll go with the Gardz primer just to be safe(there are plenty of other rooms that will use up the BIN!). I'm not familiar with the brand, so I'm looking at "Gardz Drywall Sealer," "Gardz High Performance Sealer," or "Gardz Problem Surface Sealer." Do you think the High Performance is what I should get?
Old 06-17-2012, 12:49 PM   #12
As far as I know there all the same thing.
Different print jobs
Old 06-17-2012, 01:12 PM   #13
Perfect! Thank you, Brushjockey. I'm headed out to pick it up now. I should be all good at this point.
Thanks again to all of you for this advice!
Old 06-18-2012, 04:52 PM   #14
There is actually another label they ship that under as well. They all have the same UPC.
Old 06-22-2012, 09:14 AM   #15
So I got a gallon of Gardz and painted a first coat. It looks pretty good so far and I'm going to look over the walls to see if I missed any spots and put some more Gardz on there. But do you think a second full coat of the primer is necessary as well?
bathroom circuit size..... CharlieR Electrical 14 03-25-2012 02:52 PM
multiple choice - basement bathroom venting debacle and burps denemante Plumbing 1 11-15-2011 10:50 AM
Bathroom to Laundry Room to Bathroom bcatanz10 Remodeling 2 10-10-2011 09:45 PM
Bathroom Paint - Crying Sap? stevencrider Painting 4 08-12-2010 06:21 AM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 09:29 AM
