Old 12-05-2009, 10:07 AM   #1
Punk
TuscolaMatt's Avatar
Suggestions for better blending of shades?
I've got a funky paint job going in my remodeled (in progress) living room.
A very long story short, here's one stage of re-construction:
(more at: http://polarsoft.net/remodel/ )
Here's a current picture:
I used a sponge and a brush for the transition, but I want it smoother if possible. Any suggestions? Thanks...
TuscolaMatt is offline   Reply With Quote
Old 12-05-2009, 11:25 AM   #2
(the original)
Maybe a small microfiber or foam roller squeezed out almost dry?
ratherbefishin' is offline   Reply With Quote
Old 12-06-2009, 02:53 AM   #3
sdsester's Avatar
If you are trying to get sort of a seamless color blend, dark to light, you are probably going to have to spray. You could try making the transitions using glazes of color, rather than opaque color, over a base coat, with sponges or something but spraying is going to be your best bet. I kind of like the look you are after for this room by the way!
sdsester is offline   Reply With Quote
Old 12-06-2009, 05:58 PM   #4
i've never seen a clean transition like you want without spraying of some sort, even on a small scale (canvas in the dozens of art classes ive taken.) you can get close with a lot of work but on something the scale of your wall it will be tough.
cellophane is offline   Reply With Quote
Color suggestions? kevinc Interior Decorating 2 01-04-2010 05:41 PM
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 06:07 PM
Window Films v. Solar Shades? JDuc HVAC 2 06-15-2008 09:23 AM
Hip Vents for 12/12 pitch roof - any suggestions woodworker2000 Roofing 5 10-26-2006 11:31 AM
