Successful Mission Removing Popcorn - Painting - DIY Chatroom Home Improvement Forum
Old 07-30-2007, 08:21 AM   #1
Rewards Points: 150
I dove in this weekend after HATING the ceiling's in my house for 6+ year's. In 3hr's, I stripped ALL the popcorn off the ceiling in my kitchen (325sq ft).
First I knocked it all down by running a 14" tap knife over it. Then, I saturated it with plain old water in a spray bottel, waited about 1 min and stripped it all of with the 14" knife. Did it section by section and finished in about 3Hr's.
Now I am going to just give it a sanding, prime it with 2 coat's and paint. I am very happy with the result's and can not beleive how easy it was.
MAKE SURE you enclose the space you are doing with plastic floor to wall. it does make a HUGE mess.
dcd22 is offline   Reply With Quote
Old 07-30-2007, 10:55 AM   #2
Excellent! What a job, eh? And the mess......
Are you going to re-texture it or leave it smooth?
StevePM is offline   Reply With Quote
Old 07-30-2007, 11:05 AM   #3
Rewards Points: 150
I think what I am going to do is sand it as best I can (going for smooth). From there, put a coat of primer on it and see.
I am ok if it has a little texture, just not sure if I am going to add any to the paint to make it textured.
Does that make sense??
Old 07-30-2007, 04:35 PM   #4
Sounds good! You should be able to get a smooth surface with sanding and spackling.
Enjoy the new look!
Old 07-31-2007, 10:34 PM   #5
Paint/Faux Artisan
Da Vinci's Avatar
Good job! I would recommend just one quick skim coat of mud before priming/painting - it will make the job look twice as good when done.
Good luck!
Bay Area Painting Company
Da Vinci is offline   Reply With Quote
Old 08-06-2007, 11:13 AM   #6
Rewards Points: 1,910
And you made sure it didn't contain asbestos before you dusted your kitchen with it - right?
Old 08-06-2007, 03:14 PM   #7
Rewards Points: 150
I did not have it tested BUT it was done in 1987 and beleive to have read earlier in my research that since it was '87, I would be ok.
I hope I was right!
Old 08-06-2007, 03:17 PM   #8
Rewards Points: 150
Da VInci - Would you do a skim coat then sand/prime/paint or just skim and prime/paint?
I am hesitant on doing this as I am not that good at any mudding.
How do you suggect going about this?
Old 08-06-2007, 03:57 PM   #9
I don't remember the date either but seems like it was before 1987. I just threw that out there to remind anyone else thinking about doing this to check into the possibility before they do it.
Old 08-06-2007, 04:46 PM   #10
Tired, Cold, and Damp
slickshift's Avatar
It may or may not need a skim coat
Usually under popcorn we find a level of taping/joint-compounding that is not suitable for painting (level two or three drywall finish)
If it's a "level 4" or higher you might not need it
Only you can tell us if it's smooth enough to paint w/o a skim coat
Remember, paint colors, it doesn't fill
If needed, the best way is to prime (or seal depending), skim, sand, dust, prime
slickshift is offline   Reply With Quote
Old 08-06-2007, 09:33 PM   #11
Paint/Faux Artisan
Da Vinci's Avatar
I realize you can get by without skimming, but difference is night and day from my perspective because you inevitably have gouges/scrapes from removing popcorn. It's not difficult to do, given you were adventurous enough to remove the stuff in the first place.
Buy a container of topping mud (not the joint compound which is thicker) and put some in a cheap mud pan (plastic is fine). I always mix a little water in the topping mud for a skim coat- a lot of moisture is absorbed quickly by the raw sheetrock.
Use a taping knife (again - cheap one from Home Depot will work) about 10" or 12" is best for me, but you can use a little smaller- just takes more time.
Put mud on end of knife (cover whole blade-end to end with about a 1"thick line of mud). Hold blade at a shallow angle to ceiling (in other words- keep handle of blade close to sheetrock instead of way out), and FIRMLY spread the mud on the surface. You don't want a thick coat- it's almost transparent when you put it on this thin, but it will fill up scratches and bad spots. DOn't leave a lot of ridges from mud coming off blade ends- just scrape them off too. Cover the ceiling in this manner- let dry and very lightly sand with 120 or 180 paper. Trust me, you'll be glad you took an hour or two and did this before painting.
Good Luck!
Old 04-16-2008, 06:18 PM   #12
Da Vinci,
what is skim coat ?
I'm about to DIY my 2 broom, so collecting all good info
Tx
Dai
dainova is offline   Reply With Quote
Old 04-17-2008, 04:57 AM   #13
Rewards Points: 28
Some great advice here.....Remember there is always the option of applying a "heavy" texture in place of the popcorn, this will hide all. To me it just adds ZEST, however it may not match as well with the rest of the house?
One more thing quality paint can and does fill small voids and scratches, very well I might add. If your skilled with a thick nap you can make old beat up walls/ceilings look new with a little practice. Within reason of course. If your going for the "smooth" look >>>skim coat it~
P.S.-An alcohol based primer has worked wonders for us instead of a latex or oil based. That's what I prefer.
Pro Color Painting
Pro Color is offline   Reply With Quote
Removing painted popcorn texture from ceiling cnielsen4130 Remodeling 8 10-07-2007 11:21 PM
Retexturing painted popcorn ceiling kwehnes Building & Construction 6 01-02-2007 04:36 AM
Question about popcorn ceiling J187 Building & Construction 4 06-30-2006 01:33 PM
Removing popcorn from ceiling? Doug Crf Painting 5 05-22-2006 08:23 AM
removing knockdown texture K_I37 Painting 7 05-07-2006 01:23 PM
