Stucco Paint - Painting - DIY Chatroom Home Improvement Forum
Old 11-03-2008, 10:47 PM   #1
Rewards Points: 150
stucco paint
is it better to prime a stucco house with a kind of primer made for stucco or can i use kilz2? ive read about some kind of stucco primer that is thicker than normal paint so it kind of blends the repairs in the stucco with the surrounding area. i couldn't find anything of the sort at home depot.
drewhart is offline   Reply With Quote
Old 11-04-2008, 05:19 AM   #2
Special paints you will not find in the big box stores. Well any that are worth while IMO. I recommend that you go to a real paint store ask them about primers. As far as "Stucco paint" I would use a Elastomeric product. Here is a link for a good read......
http://www.house-painting-info.com/stucco.html
Good Luck
mark942 is offline   Reply With Quote
Old 11-04-2008, 08:43 AM   #3
Stucco can be pretty tricky to repaint especially if you have repairs. Is the stucco cementitous or acrylic. Most acrylic stucco manufacturers (EIFS systems) have specialized coatings for their products. If you know what brand was used contact the local distributor. Some people have use an ultra thick primer like Peel Bond to recoat repaired areas before re-painting. Peel Bond is thick enough to give the surface a consistant texture. The trick is to do a whole panel so that it is not so noticeable.
Tommy Boy is offline   Reply With Quote
Old 11-04-2008, 09:31 PM   #4
What part of the west is the home located?
casselli is offline   Reply With Quote
Old 11-06-2008, 06:49 PM   #5
Rewards Points: 150
the house is in cleveland ohio. i don't know what kind of stucco it is. how do i tell? it was built in the twenties. i used a benjamin moore acrylic primer on the front wall and it looks ok. i went to an industrial hardware store and they recommended this kind of primer. it is an all purpose primer where stucco is the last application listed. i want to try something made specifically for stucco on the rest of the house. something thicker.
Old 11-06-2008, 06:53 PM   #6
Rewards Points: 150
man peel bond is expensive. i wish i didn't already do the front, i might have bought it just for the front. does peel bond make a paint?
Old 11-07-2008, 08:35 AM   #7
Drewhart, send me a PM with your contact number.. Since you are local, I can took a look at the job and recommend an economical solution. Peel Bond is not cheap, no doubt. If it does what you need it to then its not expensive either.
BTW- XIM amanufacturing and offices are in Westlake Ohio, suburb of Cleveland.
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
