01-07-2013, 05:21 PM
#1
Stripping wallpaper - what is this in the photo and how to fix?
Hi!
The previous owners put up textured wallpaper and painted it bright lime green and turquoise. Needless to say, it's got to go. I am using my handheld Shark steamer with part H2O part white vinegar. The wallpaper is coming of very easily, but there is paint underneath that is also coming off in some places.
Additionally, as I suspected, the walls are in need of some repair (is this called "skimming"?) Can someone take a look at these photos and tell me what this chalky feeling stuff crumbling off is? Our house is poured concrete - no drywall. The white still feels/looks like it might be plaster?
How do I repair the walls and the cracks so they are smooth again for priming and repainting? Any suggestions about what I should use? There are holes in some areas too.
Here's a link to pictures: http://imgur.com/a/izNlb#0
01-07-2013, 05:28 PM
#2
Rubbin walls since'79
You might be overkilling with the steamer , but looks typical.
Make sure to clean off the paste as good as you can also-
then prime all with a sealer called Gardz-
then do any repair/ skimming
sand that smooth
reprime mud spots,
2 coats quality paint
yer golden!
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
01-07-2013, 05:31 PM
#3
Thanks! So I'm priming before repairing? What should I use to repair the walls?
01-07-2013, 05:51 PM
#4
There are a million threads on this here- btw-
The primer seals in the paste residue- very important
seals any damaged drywall- sometime repairing without this will cause the sheetrock paper to bubble.
use a premixed taping compound like Plus 3, and a wide (12" + 6" ) mud blade.
01-07-2013, 05:52 PM
#5
Thank you :-)
01-07-2013, 05:53 PM
#6
paper hanger and painter
I will jump in here in case brush has gone for the evemimg
Yes prime all( with Gardz) after paste removal and skim coating.
Skim with joint compound
01-07-2013, 05:55 PM
#7
Ah, Chris dude yer speel check brocken...lol ??
The Following 2 Users Say Thank You to Brushjockey For This Useful Post:
01-07-2013, 06:21 PM
#8
You got the hammer down before I did
01-07-2013, 06:28 PM
#9
Sorry Hands- got a inter forum thingy going on here- all in good fun..
01-07-2013, 06:39 PM
#10
Oh it's ok. I am not going to be able to find the primer you recommended locally. Will Zissner 123 work?
01-07-2013, 07:36 PM
#11
Nevermind, I realized when you said "seals in the paste residue" you meant the glue from the wallpaper. A friend was just telling me she thought she got all the glue off, but she didn't and it destroyed the paint job.
I will hunt around for the GARDZ. Thanks for all the help!
01-07-2013, 07:37 PM
#12
Actually not even close to as well. Lots of people have that problem, we've heard.
I can get it here at paint stores, Home Despot, Menards, Ace - it can be done with an internet buy.
in the old days we pros always used oil primers to do the same thing. Gardz does it as well with less odor and faster dry. But an oil like cover stain ( thinned a little w/ mineral spirits for penetration) will still get it done.
01-07-2013, 07:42 PM
#13
Here's another interforum tip... never call wallpaper paste- glue... the official watcher of wrong words ( that would be chrisn) will come down like a bolt of lightning! lol
01-07-2013, 08:51 PM
#14
Haha, thanks. I have two questions to just make sure I have everything straight. I actually have 5 gallons of KILZ (oil based) primer in the garage and some mineral spirits on hand. Theoretically I could use that to prime/seal the paste and walls before patching and smoothing? The benefit to using the KILZ would be I don't have to prime again before painting. I'm painting a light neutral and the walls are that salmon/pink color.
If the GARDZ would be better, I found two on Amazon. One is in a red container and the other is in a brown container. Which would be the one you recommend?
The KILZ is pretty smelly though. I'm in NY so it's 30 degrees out and not exactly prime for opening windows for ventilation.
01-07-2013, 10:00 PM
#15
The kilz would work- you know what that means though- so it's your call.
You will have to prime any mud repairs because it will suck the sheen out of your paint. This could be done rolling on a spot of the paint on the patch, let that dry a bit- then go for your 2 coats. Would not have to be kilz again.
As far as your Gardz links- same stuff- diff generation labels. One is a gal, other a qt though..
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
