-   -   Stripping wallpaper - what is this in the photo and how to fix? (http://www.diychatroom.com/f4/stripping-wallpaper-what-photo-how-fix-168506/)
handsforasl 01-07-2013 04:21 PM
Hi!
The previous owners put up textured wallpaper and painted it bright lime green and turquoise. Needless to say, it's got to go. I am using my handheld Shark steamer with part H2O part white vinegar. The wallpaper is coming of very easily, but there is paint underneath that is also coming off in some places.
Additionally, as I suspected, the walls are in need of some repair (is this called "skimming"?) Can someone take a look at these photos and tell me what this chalky feeling stuff crumbling off is? Our house is poured concrete - no drywall. The white still feels/looks like it might be plaster?
How do I repair the walls and the cracks so they are smooth again for priming and repainting? Any suggestions about what I should use? There are holes in some areas too.
Here's a link to pictures: http://imgur.com/a/izNlb#0
Brushjockey 01-07-2013 04:28 PM
You might be overkilling with the steamer , but looks typical.
Make sure to clean off the paste as good as you can also-
then prime all with a sealer called Gardz-
then do any repair/ skimming
sand that smooth
reprime mud spots,
2 coats quality paint
yer golden!
handsforasl 01-07-2013 04:31 PM
Thanks! So I'm priming before repairing? What should I use to repair the walls?
Brushjockey 01-07-2013 04:51 PM
There are a million threads on this here- btw-
The primer seals in the paste residue- very important
seals any damaged drywall- sometime repairing without this will cause the sheetrock paper to bubble.
use a premixed taping compound like Plus 3, and a wide (12" + 6" ) mud blade.
handsforasl 01-07-2013 04:52 PM
Thank you :-)
chrisn 01-07-2013 04:53 PM
I will jump in here in case brush has gone for the evemimg
Yes prime all( with Gardz) after paste removal and skim coating.
Skim with joint compound
Brushjockey 01-07-2013 04:55 PM
Ah, Chris dude yer speel check brocken...lol ??:laughing:
jsheridan 01-07-2013 05:21 PM
You got the hammer down before I did:laughing:
Brushjockey 01-07-2013 05:28 PM
Sorry Hands- got a inter forum thingy going on here- all in good fun..
handsforasl 01-07-2013 05:39 PM
Oh it's ok. I am not going to be able to find the primer you recommended locally. Will Zissner 123 work?
handsforasl 01-07-2013 06:36 PM
Nevermind, I realized when you said "seals in the paste residue" you meant the glue from the wallpaper. A friend was just telling me she thought she got all the glue off, but she didn't and it destroyed the paint job.
I will hunt around for the GARDZ. Thanks for all the help!
Brushjockey 01-07-2013 06:37 PM
Actually not even close to as well. Lots of people have that problem, we've heard.
I can get it here at paint stores, Home Despot, Menards, Ace - it can be done with an internet buy.
in the old days we pros always used oil primers to do the same thing. Gardz does it as well with less odor and faster dry. But an oil like cover stain ( thinned a little w/ mineral spirits for penetration) will still get it done.
Brushjockey 01-07-2013 06:42 PM
Here's another interforum tip... never call wallpaper paste- glue... the official watcher of wrong words ( that would be chrisn) will come down like a bolt of lightning! lol
handsforasl 01-07-2013 07:51 PM
Haha, thanks. I have two questions to just make sure I have everything straight. I actually have 5 gallons of KILZ (oil based) primer in the garage and some mineral spirits on hand. Theoretically I could use that to prime/seal the paste and walls before patching and smoothing? The benefit to using the KILZ would be I don't have to prime again before painting. I'm painting a light neutral and the walls are that salmon/pink color.
If the GARDZ would be better, I found two on Amazon. One is in a red container and the other is in a brown container. Which would be the one you recommend?
The KILZ is pretty smelly though. I'm in NY so it's 30 degrees out and not exactly prime for opening windows for ventilation.
Brushjockey 01-07-2013 09:00 PM
The kilz would work- you know what that means though- so it's your call.
You will have to prime any mud repairs because it will suck the sheen out of your paint. This could be done rolling on a spot of the paint on the patch, let that dry a bit- then go for your 2 coats. Would not have to be kilz again.
As far as your Gardz links- same stuff- diff generation labels. One is a gal, other a qt though..
