Old 01-29-2011, 12:09 AM   #1
Stripping solid wood ceiling paint
I recently bought an old house built in 1940. I pulled off the hideous office tile garbage and found solid wood ceiling boards painted an odd olive drab color. I assume it was some kind of protecter they used in 1940. The deal is the house is too small to leave the dark green, so I want to strip the wood. Any way you look at it, it's going to be a nightmare. I guess i'm going to have to use stripper and Jasco is the only one i've ever used that really works. Sanding would break my neck. Any other suggestions?
Crusher is offline   Reply With Quote
Old 01-29-2011, 05:24 AM   #2
Media blasting.................Corn husk,nut shells, etc would be my choice...
mark942 is offline   Reply With Quote
Old 01-29-2011, 08:23 AM   #3
ltd
first check for lead paint .if it is do not disturb .you could put sheet rock over this or prime with oil base primer then paint a latex paint top coat
ltd is offline   Reply With Quote
Old 01-29-2011, 12:19 PM   #4
Matthewt1970's Avatar
That's what I was going to suggest. Some sheetrock and some crown moulding. The crown moulding will make it look great and keeps you from having to mud much where the ceiling and wall meet.
Old 01-29-2011, 12:30 PM   #5
Stripped wood often doesn't look that great. Save yourself the headache and just paint it a better color.
Windows is offline   Reply With Quote
Old 01-29-2011, 01:03 PM   #6
I agree, prime and repaint or cover it with dw then prime and paint.
Ceiling paint sheen options... J Barr Painting 4 05-30-2010 01:22 PM
Priming Interior Wood Doors Lovegasoline Painting 6 09-12-2009 04:48 PM
I can't paint my whole exterior before winter, and I have some exposed wood skiposwald Painting 1 10-15-2008 01:06 AM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-18-2008 12:04 AM
