Stripping Peeling Paint - Painting - DIY Chatroom Home Improvement Forum
Old 08-24-2009, 07:06 PM   #1
Stripping peeling paint
I have a roll type garage door with panels that probably hasnt been painted in many years. The wood mould has alot of peeling paint and I tried sanding it off but it is taking along time to get so little done. If I use paint stripper chemical will it do alot of damage to the wood moulding?
evergrean is offline   Reply With Quote
Old 08-25-2009, 05:00 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 122
Might be easier oan or cheaper to replace it.To answer your question, no, it should not do any damage to the molding.
chrisn is online now   Reply With Quote
Old 08-26-2009, 09:12 AM   #3
Coatings Nerd
There are some great paint strippers out there. The key with most of them is time, the longer they sit on the surface, the better they work. I like Star 10 paste, ( of course I sell it ) Works well, takes about an hour, and is somewhat expensive. $27 per qt, and a quart covers about 10 sq ft. But hey, do you want cheap, or effective.
NCpaint1 is offline   Reply With Quote
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
