Stripping / Painting A Tired Exterior Door - Painting - DIY Chatroom Home Improvement Forum
Old 03-01-2009, 06:30 PM   #1
Stretch
Stripping / painting a tired exterior door
We have a 6-panel wood entry door that is stained / varnished. It is old & tired with the varnish flaking off (baked by the sun / elements for 20+ years). We want to paint it, and would prefer avoiding strippers if possible.
Does all the varnish need to come off? If we sand off the loose / nasty stuff & simply rough up the rest with sand paper...will a good quality primer / ext. paint do the job...or will this method fail me down the road, requiring me to do it again sooner rather than later?
All the flat surfaces will be sanded down to wood (belt sander)...that is easy. It's the contours I am worried about. Going at it with sand paper will wear down the edges if I really go at it...
Thanks for the inputs in advance! If my plan of attack above is AFU, bring it on.
scheenstra is offline   Reply With Quote
Old 03-02-2009, 06:43 AM   #2
Remodeling Contractor
Use a scraper first to remove all the loose paint. Then sand so that all edges are feathered. Use a quality exterior primer and paint. Good paints cost more... Wipe with wilbond then prime. Wipe small sections at a time and cover with primer or the Wilbond will dry and loose it's effectiveness. Add penetrol to your oil based top coat to get good adhesion and flow.
Old 03-02-2009, 07:41 AM   #3
the Musigician
DangerMouse's Avatar
if it were me, i'd flat sand, but still use a stripper where needed to remove ALL old varnish. but i'm fussy that way......
although i think you'll be much happier with the end results if you take the extra step.
DM
Interior door painting and too much/too little paint richbl Painting 2 08-26-2008 04:07 PM
Stripping / painting an exterior door scheenstra Painting 5 04-27-2008 10:38 PM
