Stripping / Painting An Exterior Door - Painting - DIY Chatroom Home Improvement Forum
Old 04-23-2008, 12:30 AM   #1
Stretch
Stripping / painting an exterior door
I have a stained / varnished pine front door that I want to paint. I'm great with a hammer, not so much a paint brush... What do I need to do to prep it for paint?
Thanks in advance!
scheenstra is offline   Reply With Quote
Old 04-23-2008, 03:36 AM   #2
Do you have access to a cup gun?
mark942 is offline   Reply With Quote
Old 04-23-2008, 10:21 AM   #3
Stretch
Negative...
Old 04-23-2008, 04:02 PM   #4
J Calvin Construction
jcalvin's Avatar
Rewards Points: 150
Get some "StipeEze", some wire brushes, sandpaper, and some newspaper to put on the floor because you are getting ready to make a mess. Follow the instructions on the can and it will take the finish completely off. I just bought a $50 airless cup gun from Lowes and it does suprisingly well for a small job.
Cal
You hired WHO?
jcalvin is offline   Reply With Quote
Old 04-27-2008, 01:12 AM   #5
Pro Painter
You only need to strip if you're going to restain.
In order to paint, you do not need to strip this door.
Sand the finsih and prime with zinsser bonding primer. Then paint.
joewho is offline   Reply With Quote
Old 04-27-2008, 09:38 PM   #6
Tired, Cold, and Damp
slickshift's Avatar
Clean
Scuff sand
Wipe off dust
Prime with oil-based (alkyd) primer
Paint with quality exterior paint of your choice (acrylic or alkyd)
slickshift is offline   Reply With Quote
painting a woodstove JAVAMAN Painting 7 05-12-2009 06:47 AM
Painting over a sponge painted wall Snowdog Painting 3 03-16-2008 11:13 PM
Garage drywall painting haylo75 Painting 18 11-12-2007 08:13 PM
couple questions about painting on different surfaces joeyboy Painting 3 08-19-2007 02:33 PM
