Stripping Paint From Column Capitals - Painting - DIY Chatroom Home Improvement Forum
Old 11-10-2011, 08:26 AM   #1
stripping paint from column capitals
I have two columns in my living room and I would like to strip the paint off of the capitals to help show the detail. The capitals are plaster and I am wondering what the best approach would be, because I do not want to damage any of the plaster. Does anyone have any suggestions as to what would be the best method.
Thanks,
Lawrence
lkheisler86 is offline   Reply With Quote
Old 11-10-2011, 11:20 AM   #2
Rubbin walls since'79
Brushjockey's Avatar
Check into a product called peel away. It goes on thick, you cover it overnight and then just "peel away" the whole thing. Kinda spendy, but is cleaner to work with .
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 11-10-2011, 06:18 PM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 124
Will that work on plaster??
chrisn is online now   Reply With Quote
Old 11-10-2011, 06:25 PM   #4
I don't have much experience with it- but i don't know why not. it's not like the plaster will dissolve like the paint will.
I would definitely go to a good paint store that carries it and ask- maybe Google some more info- but if i had this issue i would look into it.
Old 11-10-2011, 07:36 PM   #5
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
I would use Peel Away smart strip, the smart strip is not caustic and does not need to be neutalized. I just used about 150 gallons of it in the past couple of weeks. The smart strip will not damage the plaster. Peel Away has a few products to choose from, but the Smart Strip is the safest and has the least amount of fumes, so it is good for indoor use. Apply it heavy and give it time to work. You may need two applications, but it will work.
housepaintingny is offline   Reply With Quote
Old 11-10-2011, 08:05 PM   #6
There you go.
Old 11-11-2011, 05:20 AM   #7
chrisn's Avatar
Rewards Points: 124
Live and learn
Old 11-11-2011, 07:31 AM   #8
Thanks for the help I will use the smart strip peel away stuff
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 09:00 AM
Painting Old House Smokin Gun Painting 36 07-05-2011 02:24 AM
oil base paints NoExperience Painting 30 09-04-2008 06:37 AM
