Stripping Paint From Bathroom Vanity - Painting - DIY Chatroom Home Improvement Forum
Old 08-28-2012, 09:50 PM   #1
Stripping Paint from Bathroom Vanity
I am trying to do a budget friendly bathroom remodel. My goal is to stain the existing vanity with a green tinted wood stain, so stripping the paint is essential. I removed all the doors and drawers, stripped them with Savogran SuperStrip, and lightly sanded them. Now that I'm on to the actual vanity frame itself, I'm having a hard time getting any paint to come off. I am open to any suggestions.
CBieber is offline   Reply With Quote
Old 08-28-2012, 10:31 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
May the force be with you.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 08-29-2012, 12:53 AM   #3
Bombastic Idiot
notmrjohn's Avatar
I get it, brushjockey, I think. Could just be the effects of the MEK.
Cb are you using semi-paste or gel stripper? It'll stick to vertical surfaces better. let it work for you.Don't be in a rush to take it off. Wait till its almost dry. Scrape and brush it off then try some more. If remover worked on parts it should work on the cabinet. Get a scraper, be careful with it, don't damage the wood, but lean into it, use some force. Tried a heat gun? Careful with it, don't damage the wood or house.
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
The Following User Says Thank You to notmrjohn For This Useful Post:
CBieber (08-30-2012)
Old 08-29-2012, 11:05 AM   #4
Gymschu's Avatar
Rewards Points: 490
Sometimes you can cover the stripper with Saran Wrap to allow it to work LONGER. May be worth a try in this case.
Gymschu is online now   Reply With Quote
Old 08-29-2012, 02:35 PM   #5
Bombastic Idiot
notmrjohn's Avatar
i just remembered, the last time I used paint remover I used an "orange oil "based product. I was suss-sceptablous at first but it really worked great. i think the reason I used it was that it was a real thick gel that really stuck to the verticals. Claimed on the jug it would stay active 24 hours but dunno bout that. Nice color and aroma too. Sorta reminded me of a girl I once knew. Not because she was pretty and smelled nice but cause she was orangy skinned and could strip paint with a withering glance.
alligator cracking lead based paint in bathroom protechplumbing Painting 10 09-02-2013 01:15 PM
How to build/attach wall hung bathroom vanity NewHomeDIYGuy Carpentry 13 12-28-2011 03:17 PM
Painting patch in bathroom ohman Painting 4 09-15-2010 11:09 PM
bathroom paint peeling jenchip Painting 12 05-18-2010 06:33 PM
oil base paints NoExperience Painting 30 09-04-2008 06:37 AM
