Is This Stripping Job Ready For Repainting? - Painting - DIY Chatroom Home Improvement Forum
Old 07-13-2011, 03:56 PM   #1
Rewards Points: 1,062
Question
is this stripping job ready for repainting?
this is the metal fire door on my shed. i used 4 little cans of Smart Strip, which works OK on flat surfaces but not too well in corners. i was wondering if i am ready to reprimer and repaint at this point, i.e. whether the little imperfections are gonna show too bad.
thanks
is this stripping job ready for repainting?-p1020873.jpg   is this stripping job ready for repainting?-p1020874.jpg   is this stripping job ready for repainting?-p1020875.jpg   is this stripping job ready for repainting?-p1020876.jpg
Old 07-13-2011, 07:52 PM   #2
Too Short? Cut it Again!
Looks like you are getting close. You need to get all that stripper off and do a little sanding. You will need to prime before painting.
The Following User Says Thank You to user1007 For This Useful Post:
amakarevic (07-13-2011)
Old 07-16-2011, 01:30 AM   #3
Question
are you sure this white stuff is the stripper? i thought it might be the primer. if it is the stripper indeed, do you think it's bad if i don't completely scrub/sand it off? cause it is one major grueling task to do...
Old 07-16-2011, 05:22 AM   #4
Ama, the white stuff does look like primer. Follow the instructions on the label for removing/neutralizing the stripper. A palm sander with some 80 weight paper will remove/feather the remaining stuff down to almost invisible under the new finish.
Tags
paint stripping
Hardwood floor stripping problems cmdrico7812 Flooring 3 09-13-2011 10:58 PM
door weather stripping Gregl13 Remodeling 1 10-08-2010 10:15 PM
Ready Seal Deck Stain jbtn9 Flooring 2 08-27-2010 11:52 PM
Getting Ready for Rough-in Inspection (Ottawa, Canada) njchan Electrical 8 05-11-2010 09:36 PM
Stripping paper messing up woodwork saggdevil Painting 2 06-08-2009 06:05 PM
