Stripping An Iron Fence - Painting - DIY Chatroom Home Improvement Forum
Old 03-17-2008, 10:42 AM   #1
Rewards Points: 101
My new home has an iron fence and gate across the front. It was painted white but apparently not maintained. There is alot of chipping and some rust spots. I want to hit it with some white Rustoleum but first I wanted to strip as much of the chips and rust as I can.
Besides a wire brush are there and attachments I can put on a drill for more of a "power strip"?
jte1130 is offline   Reply With Quote
Old 03-17-2008, 04:03 PM   #2
Rewards Points: 682
A powered sander would be much more efficient, if you can get it around the surfaces you need to strip (the power sander is flat). A wire brush on a drill is more hit and miss, and more time consuming if you want to do a good job. I don't know anything else you can put on a drill.
A wire wheel on an angle grinder might be better too.
darsunt is offline   Reply With Quote
Old 03-18-2008, 09:34 AM   #3
Rewards Points: 101
Actually I have a random orbit sander. Didn't even think of using it on this. Now to find the right sandpaper.
"T"-ing off of neighbours' fence? curls00 Carpentry 6 01-10-2009 03:39 PM
Crooked Fence - Grrrrrr Dallas Building & Construction 1 12-04-2007 06:18 PM
Height of Fence = Height of Posts Necessary Dallas Building & Construction 2 11-05-2007 09:47 AM
Wooden Top For Wroght Iron Railings ThomF Carpentry 10 11-01-2007 11:41 AM
Fence problems-Cement or No Cement WBMill Landscaping & Lawn Care 8 06-17-2007 02:36 PM
