Stripping Cypress Clapboard - Seal As I Go? - Painting - DIY Chatroom Home Improvement Forum
Old 08-19-2010, 10:48 AM   #1
Stripping Cypress Clapboard - Seal as I go?
I am currently engaged in the rather arduous task of stripping all the paint off the original cypress clapboard siding on my 1910 house in Houston. I have a couple helpers, but expect that, given my schedule and the effort involved (4 layers of paint, lots of 7' tall windows) and other miscellaneous repair work that is needed, it will be at least a month before painting can begin.
I'm using a "Silent Paint Remover" infared heater to help strip the siding. I know that this helps extract moisture out of the wood.
As I strip a section, should I use a wood sealer on that area to help protect that area/lock out moisture, or would I be OK with some areas exposed up to a month before painting? Furthermore, should a sealer be used regardless before priming?
Any advice would be appreciated.
cwrm4 is offline   Reply With Quote
Old 08-21-2010, 05:29 AM   #2
Leave it, keep fingers crossed for good weather. I have taken many houses down to bare wood and then went back to prime. But then I like to do things in a systematic way & worry about weather later................
mark942 is offline   Reply With Quote
Bosch Dishwasher leaking along bottom seal of door mtbdudex Appliances 14 10-13-2012 08:49 AM
seal a polished marble bathroom floor? tarheelblue Flooring 21 01-12-2012 11:58 AM
do I need to seal tiles, and if so, when...? rtoni Tiling, ceramics, marble 5 03-26-2010 09:41 PM
To seal or not to seal tops of IPE rocketdoctor Building & Construction 3 09-20-2009 12:04 AM
Bad driveway patch and seal work fastfan Landscaping & Lawn Care 1 09-09-2009 08:14 PM
