To Strip Or To Sand? - Painting - DIY Chatroom Home Improvement Forum
Old 05-30-2011, 02:37 PM   #1
To strip or to sand?
Hi all,
My old deck is covered with some peeling paint. I tried to use some stain stripper and a power wash but it didn't really work...I beleive what's there is some BEHR exterior paint, because I see some old gallons left in the garage by the previous owner. And I read somewhere on this forum that it is a paint to get it off...I need some advices please..
Should I just sand it down with some 60 grit sanding discs using my orbital or I should go get myself some paint stripper and start the dirty work of stripping the paint first?
I plan on staining it afterwords...
Thanks!
Domochu is offline   Reply With Quote
Old 05-30-2011, 02:44 PM   #2
Too Short? Cut it Again!
Not sure how to answer your question without knowing what is on the deck. It could take a lot of stripper to strip a deck. If the screw heads or nails are nicely surfaced you might think about renting an orbital, not drum type, floor sander and spending a bit on paper. I guess start with 60 grit but if you have a lot of paint it will clog up quickly.
Old 05-30-2011, 03:00 PM   #3
Is flipping some of the boards a viable solution?
The Hows and Whys of Furring Strips. Part-1 Willie T How To Guides 12 03-01-2013 02:58 PM
Need Help - Failed Patio in Sand Install lews Landscaping & Lawn Care 5 04-19-2010 06:34 AM
how to light sand texture ceiling mtom01 Painting 4 03-13-2010 12:11 AM
Best Way to Establish Plantings Over Sand flyboy Landscaping & Lawn Care 4 04-07-2009 09:38 AM
painting sand over sand heather Painting 1 04-03-2007 10:35 AM
