Streaks In Ceiling Paint - Painting - DIY Chatroom Home Improvement Forum
Old 08-30-2009, 10:33 PM   #1
Streaks in Ceiling Paint
I have new drywall that I primed.
I spray painted the ceilings white and they looked awful so I rolled them with more white paint. I can still see streaks everywhere.
The walls and ceilings have a thick orange peel texture so I used a thick nap roller.
What am I doing wrong?
kntry is offline   Reply With Quote
Old 08-30-2009, 10:59 PM   #2
What brand/Mfg of paint?
Sounds like you are pressing too hard with a roller
Old 08-30-2009, 11:23 PM   #3
The DIYer Assistant
Hey kntry, when you say "spray painted" do you mean you used an airless paint sprayer, or you used a spray paint can to paint the ceiling? Uneven application of spray will certainly show up through multiple coats. Also when rolling make sure to use a "w" pattern and maintain a wet edge, same as with a normal wall. If you just roll straight, you'll probably end up with lines that show up around your ceiling.
TheDIYerGuy is offline   Reply With Quote
Old 08-31-2009, 08:20 AM   #4
No, I used an airless sprayer.
I'll have to try the W trick. I did roller it in straight lines.
When I sprayed the ceilings, I used Valspar from Lowe's. I know, I was in a hurry and the paint stores were closed. The rolled paint was PPG.
Thank you
Is ceiling paint special? SR996 Painting 2 03-27-2009 05:51 PM
Ceiling paint? slickracer Painting 9 02-05-2009 04:46 PM
Ceiling paint G Archer Painting 3 01-26-2009 10:07 AM
Paint on ceiling in error michjona Painting 5 10-07-2008 02:21 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-18-2008 12:04 AM
