-   -   Streaks in Ceiling Paint (http://www.diychatroom.com/f4/streaks-ceiling-paint-51999/)
kntry 08-30-2009 10:33 PM
I have new drywall that I primed.
I spray painted the ceilings white and they looked awful so I rolled them with more white paint. I can still see streaks everywhere.
The walls and ceilings have a thick orange peel texture so I used a thick nap roller.
What am I doing wrong?
Scuba_Dave 08-30-2009 10:59 PM
What brand/Mfg of paint?
Sounds like you are pressing too hard with a roller
TheDIYerGuy 08-30-2009 11:23 PM
Hey kntry, when you say "spray painted" do you mean you used an airless paint sprayer, or you used a spray paint can to paint the ceiling? Uneven application of spray will certainly show up through multiple coats. Also when rolling make sure to use a "w" pattern and maintain a wet edge, same as with a normal wall. If you just roll straight, you'll probably end up with lines that show up around your ceiling.
kntry 08-31-2009 08:20 AM
No, I used an airless sprayer.
I'll have to try the W trick. I did roller it in straight lines.
When I sprayed the ceilings, I used Valspar from Lowe's. I know, I was in a hurry and the paint stores were closed. The rolled paint was PPG.
Thank you
