Strange Drywall Problem - Painting - DIY Chatroom Home Improvement Forum
Old 08-14-2011, 11:22 PM   #1
strange drywall problem
We are redoing our bathroom and have a strange problem that just came up. We installed a vanity with a granite top where our old vanity was (granite top secured with clear silicon 2). The drywall behind it is the old painted drywall. It was very sturdy...no dampness, bubbles, stains, or soft spots. It had, I believe, a coat of drywall mud on it. When he went to sand it down in order to prime the walls, he noticed a yellow stain on about a a foot section and a hole formed in at the edge of this section. We have never smoked anywhere remotely around that section of the house soit can't be due to nicotine, and the water pipes are not near it (plus the water in that room has been turned off for nearly 3 months). The stain looked almost a urine color. Our drywall guy, who has been doing this for a long time, say he has never seen anything like it. Has anyone heard of anything like that, and could suggest why this may have happened?
bosease is offline   Reply With Quote
Old 08-15-2011, 03:11 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 614
A pic sure would be helpful
Old 08-15-2011, 03:39 AM   #3
C&R
C&RImprovements's Avatar
I've heard of old mud truning a yellowish color, but seems like it would be in a bigger area.
C&RImprovements is offline   Reply With Quote
Old 08-15-2011, 04:33 AM   #4
m1951mm's Avatar
It could also have been stained by soap bleeding behind the paint??????? Not totally sure how to get paint to stick two a soapy surface?????
m1951mm is offline   Reply With Quote
Old 08-15-2011, 07:09 AM   #5
Rubbin walls since'79
Brushjockey's Avatar
Try spot priming it with BIN pigmented shellac. If it will hold the coat, that will hold the stain.
Brushjockey is offline   Reply With Quote
Old 08-15-2011, 10:11 AM   #6
It would be very helpful if you could send a pic.
if the hole is a small pin hole size at the edge of the stain...it could be possibly caused by termites. press all around and inside the stained area to see if any spots sink in and form a trail.
no alarm yet until we all see the photos.
HDPaintPro is offline   Reply With Quote
Old 08-15-2011, 11:20 AM   #7
Unfortunately it has already been covered up and I didn't take a picture.
In talking to the drywall guy this morning, it did not have mud on it, but happened to the old drywall and they saw it when they went to prime. Strange thing was we didn't notice it being like that when when we put in the vanity.
Old 08-15-2011, 11:22 AM   #8
I'm sure it's not termites...thank goodness.
Old 08-15-2011, 12:47 PM   #9
Do you have a cat?
Drywall Problem jennn999 Drywall & Plaster 2 08-12-2010 10:48 PM
strange pattern on ceiling drywall kelley4180 Drywall & Plaster 21 11-23-2009 04:13 PM
Strange Problem with My Furnace chenjijc HVAC 14 11-04-2009 09:05 PM
drywall potential problem mmhendrie Drywall & Plaster 8 04-04-2009 08:23 PM
