Old 04-11-2007, 09:46 PM   #1
Stop rusting brick lintels ?
How do you prep it so it won't rust again ?
VA Beach Trimmer is offline   Reply With Quote
Old 04-11-2007, 10:46 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Just as you would a car. Grind down to bare metal and use the appropriate primer and sealer.....
- Build Well -
Old 04-14-2007, 07:55 AM   #3
I've been told that once it rust it will always come back..I thought about breaking metal over them, but I don't know what i would fasten it to..i'm talking 19 windows on a 15 year old house..Tall and hard to get to windows...
Old 04-16-2007, 04:18 PM   #4
Pro Painter
It's not necessarily true that the rust will always return. Make sure to remove all the old rust by sanding, grinding, or a chemical remover/protectant.
joewho is offline   Reply With Quote
Old 04-16-2007, 09:27 PM   #5
Eibwen
I would try sanding/brushing well followed by some naval jelly. Rinse well and paint with an oil based primer and top coat versus a water based paint.
Where bouts in Va Beach?
Sammy is offline   Reply With Quote
Old 04-17-2007, 01:40 AM   #6
Near town center..
Old 04-17-2007, 06:56 PM   #7
Eibwen
Cool!
Kempsville..
Where we all end up eventually after discovering oceanfront property really IS expensive and sand in your shorts really isnt fun.
water leaking through brick chimney quigleybmd Concrete, Stone & Masonry 45 02-26-2013 05:26 PM
Bad Brick Mortar ??? kourso Building & Construction 21 11-08-2010 01:11 AM
Cheaper masonry alternatives to brick? Jemo Building & Construction 9 05-18-2007 01:31 PM
Brick: to paint or not to paint, that is the ? Turnip Painting 3 04-15-2007 11:06 PM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 08:17 AM
