Stomp Texture On Old Plaster Ceiling? - Painting - DIY Chatroom Home Improvement Forum
Old 02-21-2010, 01:12 PM   #1
Question
Stomp texture on old plaster ceiling?
I have a very old apartment building that sat vacant without heat for 5 years and all the paint is popped and peeling from the ceilings and walls; I need to get them painted again. I started scraping the ceiling and alot of it comes off with medium effort, then there are areas that do not budge. I am wondering if I can stomp right over this(after I scrape all that will come loose), or if i hit it with a primer coat will it hold up and not pop further to just be painted? The plaster is very smooth and hard, like the smooth side of durock with a yellowed color to it.
Thanks!!
flatlander745 is offline   Reply With Quote
Old 02-23-2010, 02:03 PM   #2
NAV
Yep, scrape off the loose, prime with a solvent based primer and then you have a couple options.
  1. just paint it and have it look like crap
  2. Skim coat it so it is smooth
  3. skim coat and texture - if you do not feather the transition from the peeling paint to the bare substrate you may see the transition through the texture.
NAV is offline   Reply With Quote
Venetian Plaster FYI Plaster Ayn Painting 10 06-30-2010 11:26 PM
Can you texture plaster walls? destes50 Painting 5 11-06-2009 09:51 AM
How to remove plaster bathrom ceiling. scotty8 Building & Construction 2 10-25-2009 12:35 PM
Is my contractor suggesting the correct way of redoing plaster ceiling? karenldee Building & Construction 7 10-23-2009 10:47 PM
Blending ceiling patch with existing sheet-rock (slight texture) gmhut Painting 3 07-29-2008 11:16 AM
