Sticky Stain - Painting - DIY Chatroom Home Improvement Forum
Old 07-09-2012, 01:17 PM   #1
Rewards Points: 588
I have a home theater stand that I am selling. A while ago I put a plug in air freshener on top of it and the gel crap leaked out and took off the stain in a pretty large area. Now I wanted to attempt to fix this and I found stain that matches pretty good. I put some stain on it but it was not taking to the wood and just wipes right off I sanded a little and put a thick layer of stain on that area and let it dry. Well, now it looks better than it did but it's a sticky mess. What can I do here? I actually already have someone wanting to buy it. Lol, I put it online before I realized it was sticky.
nikeman is offline   Reply With Quote
Old 07-09-2012, 06:09 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Stain is meant to go on raw wood- it will not be absorbed into the finish, it will just sit on top.
It takes a bit of artistry, but stain ( or pigments) can be put into varnish or clear coats and built up to hide stuff like that.
but not a novice job.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 07-09-2012, 06:33 PM   #3
Rewards Points: 588
How is it done? I'm always up for learning stuff.
Old 07-09-2012, 08:30 PM   #4
Too Short? Cut it Again!
I am not wild about them but they have their place. Gel stains will sit on the surface. The are a glaze more than a stain.
You are going to have to get that sticky stuff off. You will probably end up stripping the top.
Old 07-09-2012, 08:42 PM   #5
Rewards Points: 588
I got the sticky stuff off. It just took the stain off that I put on so it's back to how it was. Can I use a paint? Will that be really obvious? What's this gel you speak of?
Old 07-09-2012, 08:58 PM   #6
You might get away with using paint in a glaze. You make glazes by suspending small amounts of pigment in a solvent/carrier like mineral spirits for oils and acrylic medium like Floetrol for waterbased. It is a tricky, trial and error process and if you dillute paint too much you ruin its properties. You should use pigments intended for making glazes. I would not use paint for this unless you plan to redo the whole thing.
Gel stains are essentially glazes too I guess. The stain is suspended in a gel carrier and you wipe it on to achieve the desired color. It is best to add layers rather than trying to do it in one pass. It will take some experimentation and I will warn you gel stains are not cheap. You can get them in small amounts though. Make sure they are fresh and within the expiration dates or you could have another sticky mess on your hands. Here is a URL for Minwax gels stains. There are other brands out there. A woodworking store will have the best selection but your paint store should have the basic colors.
http://www.minwax.com/wood-products/...nwax-gel-stain
Old 07-09-2012, 09:51 PM   #7
The part the Sds is missing is that all the above are not final finishes. they are going to sit on top and rub off.
Gel is not a glaze. Glaze is actually a finish , thinned out. will give some protection. You can go to the store and buy glaze- either in oil or waterbase.
I have a friend who went to school for a year and a half to learn how to do exactly this. It is now his biz.
Hard to instruct in a paragraph.
I use a varnish or other clear as a base and add color to it and blend in- after removing the stain as much as possible. Then when i'm happy with the look ( might be 4 or 5 layers) I put a finish across whole area.
The Following User Says Thank You to Brushjockey For This Useful Post:
user1007 (07-09-2012)
Old 07-10-2012, 07:37 AM   #8
Thanks for catching that! I just assumed the OP knew he would have to follow with a coat or two of finish.
Old 07-10-2012, 02:08 PM   #9
Rewards Points: 588
I am assuming I should use water based since the stain came off so easily to begin with? I'd like to know what's in them damn air fresheners that cause them to take stain off of wood!
Old 07-11-2012, 02:06 PM   #10
Rewards Points: 588
Never mind. Someone is taking it today with the stain in the stain.
Old 07-14-2012, 12:57 PM   #11
Phil - "the Paint Guy"
True glazes are not finishes. Glazes should always be topcoated with a finish. Tinted polys used as a glaze are still topcoats. you can use a gun as a hammer but it is still a gun.
Cpcphil is offline   Reply With Quote
Fiberglass door, gel stain, and nervous breakdown wit's end Painting 8 10-26-2011 11:10 PM
Removing stain from deck machouinard Painting 20 09-08-2011 10:12 PM
Deck stain project gone bad - HELP brownnl Painting 13 03-15-2011 02:57 PM
Sticky Hardwood Floor Stain after 5 days new owner 730 Flooring 4 05-25-2009 07:27 PM
Help! Sticky, tacky deck stain rainytown Painting 5 10-22-2008 04:57 PM
