Steps For Painting Pine - Painting - DIY Chatroom Home Improvement Forum
Old 04-30-2009, 08:55 PM   #1
Rewards Points: 26
steps for painting pine
I built a couple of beams out of 1x8 pine boards that I will be putting in my kitchen. I am going to sand them and fill any knots with wood putty and then plain on painting them an off white color. I have some oil primer and oil paint from sherwin williams that I used on my cabinets that I would like to use on the beams. Is there anything special that I need to do for these pine boards for painting them and getting a good finish? Thanks
ponch37300 is offline   Reply With Quote
Old 05-01-2009, 12:12 AM   #2
Not really, just make sure that the primer/paint are both interior products.
Prime the wood with oil primer, wait; paint the wood with oil paint (2 coats), wait. Install. (Follow the directions on the can of course).
The only rub is if you are using oil-based wood filler. Make sure you allow the filler to *fully* dry before applying any paint/primer. The solvent in the primer will weaken the filler and it will likely pop out!
joenusz is offline   Reply With Quote
Old 05-01-2009, 09:27 PM   #3
Rewards Points: 26
Thanks. I just was wondering how the knots would take primer and paint.
Old 05-01-2009, 09:31 PM   #4
Considering that you're filling the knots, they should be fine. Wood filler is normally paintable, but check the instructions for your specific filler. As long as the filler does not fall out of the knots, there shouldn't be any problems.
Old 05-01-2009, 11:23 PM   #5
Matthewt1970's Avatar
Rewards Points: 1,098
I would hit the knots once or twice with a spray can of Bin. Then oil prime it.
Old 05-02-2009, 12:52 AM   #6
Rewards Points: 658
If you use a shellac based primer, you won't have problems with the knots showing through the paint later on.
gma2rjc is offline   Reply With Quote
Rebuild concrete steps leading to basement gruntman Building & Construction 32 09-30-2009 11:55 AM
Brick steps failing sk8z Building & Construction 10 03-28-2009 03:16 PM
White Pine Hard-Wood floors? MrShadetree0222 Flooring 9 11-04-2008 08:24 AM
wood front porch steps dlhein Carpentry 4 05-11-2008 08:06 PM
New Oak Floor - Pine Steps Solution Mikee Flooring 1 11-19-2007 11:29 AM
