Steps On Painting Exterior Of Home - Painting - DIY Chatroom Home Improvement Forum
Old 04-17-2014, 11:36 PM   #1
steps on painting exterior of home
Hello all,
I recently posted on advice of an inexpensive exterior house painting and was told tk do it myself. I just need help on what steps I need to take to be successful. This is a trade I know nothing about.
1) I assume removal of the old paint is required. Whats better to do, sand or pressure wash?
2) I dont know what kind of wood I have, but its nothing special. Do I need coat(s) of primer?
3) I live in Washington state and rains bad. Is there a certain paint I need, and how many coats?
4)ive seen painters spray on paint. Does rolling work as good?
If there is any more info/advice you have, please share it. Hoping to do it this summer.
StarStryker11 is offline   Reply With Quote
Old 04-18-2014, 04:11 AM   #2
Rewards Points: 14,020
What condition is the paint in now?
Only places that may need sanding are where the paints peeling. It gets scraped with a paint scraper, then sanded to feather it out to get rid of the step.
Any bare wood will need priming before painting.
If the old paints not peeling, and the woods in good condition then there's no need to remove the paint, prime, or sand it, it just needs to be cleaned.
A pressure washer works best to clean it.
I'd never suggest a first time DIY try and use a paint sprayer.
Most often a brush is used when painting an ext.
Zinsser 123 as a primer works great.
Using a quality brush like a Purdy brand will hold more paint, drip less, and leave less brush marks.
Old 04-18-2014, 05:40 AM   #3
Rewards Points: 5,988
Keep in mind painting is only about 20% of the job the rest is is the prep. As A first timer I would suggest talking to your friends maybe one has some experience and would be able to help get you started.
ToolSeeker is online now   Reply With Quote
Old 04-18-2014, 07:51 AM   #4
Gymschu's Avatar
Rewards Points: 934
This is one time where checking out a lot of youtube videos would help.
Old 04-18-2014, 08:05 AM   #5
Many spots are peeling and have exposed wood on the trim. The paint on the body? of the house is good and not peeling.
Tags
exterior , home , paint , tips
Basement Steps Branden Building & Construction 13 12-07-2012 07:14 PM
Painting the Inside of a Log Home teamcanada Painting 5 07-25-2010 11:58 AM
Painting Exterior of Home Khoward Painting 1 06-08-2009 06:03 PM
steps to building a home? am i correct? katerwal Building & Construction 2 03-12-2005 11:14 AM
