Old 09-22-2011, 12:42 AM   #1
Steps to adding wallpaper and paint to an old piece of furniture
I have an old piece of furniture that I use as a library because it has sliding glass doors but it looks outdated. I'd like to stick a border type wallpaper (prepasted kind) and then paint the whole thing. Does the library need some type of preparation so that the spray paint adheres well to it? How about the border? Do I go the traditional way by soaking it in lukewarm water or should I use something like ModgePodge to make sure it stays there.
Girly_girl is offline   Reply With Quote
Old 09-22-2011, 06:36 AM   #2
Rubbin walls since'79
Brushjockey's Avatar
Lightly but thoughly sand the whole piece to break the gloss of the finish, wipe clean.
I don't know if spray cans would be what I would use, but they would probably work. Would be best to use a primer first- one that claims good adhesion.
If the primer is under where you put the border- i think that would help. What is under , or the paste involved would be more important to it sticking than anything you could put on top.
You could also brush on some vinyl to vinyl adhesive after you got the boarder wet- that would also help it to stay.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 09-22-2011, 05:54 PM   #3
paper hanger and painter
chrisn's Avatar
[quote=Brushjockey;733570]Lightly but thoughly sand the whole piece to break the gloss of the finish, wipe clean.
You could also brush on some vinyl to vinyl adhesive after you got the boarder wet- that would also help it to stay.[/quote]
forever
Tags
wallpaper
Wallpaper removal and lead paint risk? rhena Painting 12 06-07-2011 05:30 PM
Paint over Wallpaper CruiseDivaNJ Painting 24 05-23-2011 12:50 PM
Can I paint over wallpaper primer? CLM Painting 3 07-15-2009 04:40 AM
oil base paints NoExperience Painting 30 09-04-2008 06:37 AM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-18-2008 12:04 AM
