For Stencils Should I Use A Brush Or Roller? - Painting - DIY Chatroom Home Improvement Forum
Old 01-08-2012, 01:50 PM   #1
Rewards Points: 184
For stencils should I use a brush or roller?
Can I get away with 1 coat using the top quality paint? (The stencil is being painted over a much lighter color wall).
TIA
abefroman is offline   Reply With Quote
Old 01-08-2012, 04:26 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Google stensiling and get a lot of education. If the stencil is going to be total opaque , you could use a mini roller.
The hardest part is having the paint not creep under the stencil. There are a number of ways to combat this- use a spray on rubber cement adhesive is one.
But the old way is to use a stencil pounce brush. That way you are not wiping or forcing paint under the stencil.
Might have to go to an art supply store for this.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 01-08-2012, 04:27 PM   #3
Gymschu's Avatar
Rewards Points: 240
Not an expert by any stretch with stencils, but, most people I see that do them use the round brushes and use a "dobbing" technique to fill in the stencil. I would think a roller would be too sloppy.
Gymschu is online now   Reply With Quote
Old 01-09-2012, 05:56 AM   #4
ARC Painting's Avatar
if it isnt too big for your stencils, you could use a small 4" foam whiz roller. they are quite versatile
a roller might be better for a DIYer, since it will be easier to keep paint in the lines...
Toronto Painters, House Painting
Facebook: ARC Painting Toronto
ARC Painting is offline   Reply With Quote
The Following 2 Users Say Thank You to ARC Painting For This Useful Post:
abefroman (01-09-2012), Gymschu (01-09-2012)
Any tips for faster roller and paint brush cleaning/rinsing? noone Painting 17 08-13-2011 04:50 PM
best type of roller brush for oil on hardwood looney Flooring 2 01-28-2011 05:31 PM
All surfaces painted with a brush different from surfaces painted with a roller. praktikal Painting 16 04-06-2010 09:45 PM
Cutting - in Illinois G.C. Painting 11 11-24-2008 03:04 PM
Paint brush and roller cover lifespan dyier Painting 10 02-25-2008 12:10 PM
