Started Stripping Paint Off Wood! - Painting - DIY Chatroom Home Improvement Forum
Old 06-20-2009, 10:35 AM   #1
Started stripping paint off wood!
Hi I started stripping paint off some wood door frames. I have decided to stop, it is too much for one person. So now I want to prime and paint them what do I do before I prime it? I am very new to home improvements...
kristiem is offline   Reply With Quote
Old 06-20-2009, 10:54 AM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
Sand it. Both to give the surface some groves for the new paint to bite into and also to smooth out any bumps and whatnot. Spend more time where you stopped stripping the wood so it blends nice. The more time you spend sanding, the better your finihed job will look. Oil based primer is recommended for any bare wood. If you suspect the paint on there now is oil based, primer all of it, if not, just the bare wood.
Should I paint the Crawl Space Wood Joists? They are exposed? twilightcall Painting 11 09-21-2009 08:46 AM
Stripping paint from metal? Sliding Man Painting 4 10-09-2008 10:24 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-17-2008 11:04 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
Can I acheive wood tone with paint? Offalot Painting 10 07-14-2007 06:34 PM
