Staining A Wood Walkway - Painting - DIY Chatroom Home Improvement Forum
Old 03-31-2010, 09:36 AM   #1
staining a wood walkway
We have a wood walkway that sits on the ground at our cabin. The wood is a year old and is treated. I would like to stain it but wonder about the moisture since it is on the ground.
brendam is offline   Reply With Quote
Old 03-31-2010, 10:39 AM   #2
the Musigician
DangerMouse's Avatar
Hi and welcome to the forum.
I'm not sure what you mean by moisture. From the stain?
Or the wood is already moist and how will that affect the staining process?
DM
Old 03-31-2010, 11:26 AM   #3
wood walkway stain
Hi-
Is it possible to stain a wood walkway that is made of treated lumber if it in a very moist environment (next to a lake).
I would like some color on it but worry that nothing will penetrate.
Old 03-31-2010, 12:07 PM   #4
the Musigician
As long as the wood surface is dry, I don't think there will be a problem, however, I'd be inclined to test on a scrap if available, or a spot not easily seen. Others here may have other opinions and/or ideas.
DM
Old 04-01-2010, 01:45 PM   #5
I think you'll be fine. SW Deckscapes. Semi-Transparent colors or the Toner.
AlabamaGuy is offline   Reply With Quote
Tags
decks , solid color wood stain , stain
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Staining Wood - When to use wood filler markronz Carpentry 8 03-04-2010 08:15 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
Staining Wood Fence art2670 Carpentry 2 11-14-2007 01:15 AM
