Staining A Wood Fence With A Pump Sprayer? - Painting - DIY Chatroom Home Improvement Forum
Old 07-06-2010, 12:54 PM   #1
Rewards Points: 260
Staining a wood fence with a pump sprayer?
I need to stain my wood privacy fence and rather than brushing it one, I'm considering using a pump sprayer to spray it on. Has anyone ever done this or do you know if this is even possible? This is the sprayer that I have. Thanks!
Jesse
jpearson311 is offline   Reply With Quote
Old 07-06-2010, 02:44 PM   #2
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Jesse
You can using a quality sprayer, but you will still have to back brush, the sprayer will only apply the stain, brushing will work the stain evenly.
housepaintingny is offline   Reply With Quote
Old 07-06-2010, 02:50 PM   #3
Rewards Points: 260
So spray it on with a sprayer and then spread it evenly with a brush? Thanks!
Jesse
Old 07-06-2010, 05:02 PM   #4
As politely as I can,, I'm not sure your sprayer comes under the heading of a quality one. Maybe you can try it on one section first. You are going to want the stain to penetrate good, brush is good for this. I know people use them sprayers for stain but when I tried it once,, it was quite the mess, and it was on a deck, not a verticle fence. Good luck with your prodject.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 07-06-2010, 07:06 PM   #5
Rewards Points: 616
We use high end solo backpack pump sprayers for spraying various materials as needed, they are ment for spraying thin oil base material and they spray a nice even fan, you can then clean them out with thinner/mineral spirits without any damage to the pump sprayer or seals, the cheaper pump sprayers ar not quite ment for what you want to do and the internal parts are bottom line.
HELP! New WOOD FENCE is Splitting jesse423 Carpentry 16 07-27-2010 06:09 PM
Metal posts for wood privacy fence dnbharrin Landscaping & Lawn Care 3 07-14-2010 08:50 PM
staining a wood walkway brendam Painting 4 04-01-2010 12:45 PM
How to pre-treat wood for fence? nebben Landscaping & Lawn Care 3 04-29-2007 09:14 AM
privacy fence wood question mr_man Building & Construction 2 04-10-2007 10:09 PM
