Staining Wood - Painting - DIY Chatroom Home Improvement Forum
Old 06-17-2011, 10:24 PM   #1
Staining wood
I'm staining a table top, and after reading the directions it says I have the option of using a rag to wipe it on or a paintbrush to paint it on... I was thinking the rag idea would be best but wanted to hear any other opinions....
KDOC is offline   Reply With Quote
Old 06-18-2011, 03:22 AM   #2
Too Short? Cut it Again!
It depends somewhat on the type of stain you are using, the wood your are staining, and depth of color you want to leave behind. The thing to remember is that to the point the wood will not hold any more stain, you can add more color with multiple coats. If you put the stain on too heavy and do not wipe the excess, you could end up with something darker than you expected or wanted.
Soft woods like pine and fir will absorb more stain and faster than hardwoods like hickory and oak and you can get obvious over saturation points where your work overlaps if you do not even it out quickly as you go with a cloth.
I don't think I have ever stained anything where a cloth or two was not used in the process at some point. Messy but no other way to achieve the desired look.
Brushing the stain on and chasing after the excess with a soft cloth is sort of a hybrid approach to the two options you mention. I always preach good brushes for anything and the same for stain I guess. Staining may be one place where I could see using inexpensive foam brushes to put the finish on with a cloth ready in the other hand to blend it in.
If you opt for gel stain you will probably want to wipe it on.
Don't be afraid to ask the folks at a real paint store for advice and recommendations.
Old 06-18-2011, 07:09 AM   #3
Keep in mind that soft woods like pine needs a prestain conditioner to reduce splotchy staining.
The end process of staining is to wipe off the excess after it has penetrated for a few minutes. I just skip the brush process(which usually takes longer) and always use a rag. Brushes do help in getting into tight corners, edges, and intricate patterns.
Old 06-18-2011, 07:14 AM   #4
DIY staff
Rewards Points: 7,174
I prefer cotton rags over a brush for most things---Remeber Sdsesters advice---The stained wood must be wiped off after the stain is applied--
You want the stain IN the wood--not on the surface--so apply--wait a minute or two--then wipe again with a clean cloth.
Old 06-21-2011, 09:56 PM   #5
Awesome. Worked great thks
Question About Staining a Wood Deck LittleBonnie Painting 0 05-12-2011 11:52 AM
using soft wood sealer prior to staining minchu Painting 0 06-21-2010 12:16 PM
staining raw weathered wood pleasehelpme Painting 2 06-17-2009 06:55 AM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 12:19 PM
Staining Wood Floor -- Use Polyurethane or FLOOR Polyurethane? proofer Painting 2 04-05-2008 08:47 PM
