Staining Vs Just Sealing Preserved Wood Deck? - Painting - DIY Chatroom Home Improvement Forum
Old 05-28-2010, 11:25 AM   #1
Rewards Points: 101
Staining vs just sealing preserved wood deck?
I have a new deck made of PT wood. It has been a number of years since I last owned one.
Would it be ok to just seal it rather than use an oil-based semi transparent stain as I did last? Both, I know have to be repeated each year, but at least clear sealer won't show stain irregularities/blotches as it wears out each season.
I read also that I should wait at least 2 months for the wood to weather.
Or have stains improved in the last 30 years?
Grateful for any feedback. I'm in the wet Pacific NW.
Hossenfeffer is offline   Reply With Quote
Old 05-28-2010, 05:20 PM   #2
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
A translucent is fine, but will only last about a year. A semi solid stain will last a few years if you prepare the surface properly first and use a quality stain, you won't have blotchy spots if you prepare the surface properly and apply the stain correct, a semi solid has more pigment than a translucent, so it will provide more uv protection and is more durable, proper cleaning using a quality deck cleaner and low pressure is key. Sanding may be necessary too
housepaintingny is offline   Reply With Quote
sealing a deck cdundon4va Carpentry 2 11-16-2009 06:06 AM
Sealing cypress wood and beams MDS58 General DIY Discussions 3 10-08-2009 08:58 PM
Staining Problems on a New Cedar Deck nleo27 Painting 15 09-01-2009 12:14 PM
composite vrs. wood deck materials rcassidy Building & Construction 2 04-20-2009 06:33 PM
sealing a very old wood deck browneyesbloo Building & Construction 6 09-23-2008 09:47 PM
