Staining Question - Painting - DIY Chatroom Home Improvement Forum
Old 10-08-2009, 01:01 PM   #1
staining question
I have big sized bar to stain.
I've read that you put on the stain in a small section let it set for a while and then wipe it off. Then move on to the next section etc.
I have some questions:
1) When you go to the next section and you overlap the stain you just put on, won't that make it darker where the 2 sections meet. How do you make sure that it's even.
2) Also would it be possible to do a small section one day and then come back a couple days later and do the next section overlapping a little. Will this be even staiing or will you notice differences in the two stained areas.
it99 is offline   Reply With Quote
Old 10-08-2009, 01:21 PM   #2
Too Short? Cut it Again!
You will not notice much overlap if you work the stain properly. The idea is not to get too far ahead of yourself so stain is on one area longer than another before you can get to it to wipe it off. Sometimes the stains that you rub on and rub off work better for an application like yours.
Can you recruit someone to work with you? The extra pair of hands will make it easier since one of you can apply the stain and the other can take it off.
You can wait days between staining different sections. Just make sure you clean of any dust that accumulates. Make sure to always keep your stain stirred.
Old 10-08-2009, 01:45 PM   #3
question
what do you mean by 'stains that you can rub on and then off'.
I thought that was what I was talking about.
I'm using a oil based stain which I plan to rub/paint on and then I rub it off a few minutes later.
Old 10-08-2009, 02:49 PM   #4
I was thinking something like one of the gel stains with poly that you put on and than polish off.
http://www.generalfinishes.com/tips/oilbase.htm
Deck Staining Question Punjabtantrum Painting 8 06-23-2009 10:51 PM
Deck Staining question boddington Painting 3 05-04-2009 02:37 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
New service Question Onytay Electrical 1 10-24-2007 05:47 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 10:17 PM
