Old 04-18-2006, 04:03 AM   #1
Question
Staining problems..
I bought an unfinished cabinet from Lowes & I am trying to stain it, I am using Minwax Polyshades(satin & polyurethane)1 Step BomBay Mahogany Satin.
I didn't treat it with anything before applying the stain.
I think its OAK.
Well, my husband tried to stain one of the doors on it & it has some like thick spots on it that are just way to dark, I stained the other door & it looks so much better.
I noticed that while he was staining the one door it started to like get these tiny bubbles in it. Whats that???
I was told to lightly sand over the doors with "Steel Wool" so I did & it didn't lighten up the door he had done. It looks kinda gummy in certain spots. So, then I tried using some sandpaper(400superfine) & it isn't working.
I used a paint brush to apply the stain also.
Any advice ??? Thanks
Cricketsz28 is offline   Reply With Quote
Old 04-19-2006, 11:15 PM   #2
Staining problems..
Stains consist of three components: pigments, dyes and a carrier. The carrier determines whether the stain is oil- or water-based.
Staining permanently changes the wood's appearance, so always test a stain before applying it. One option is to test stain on an area of the piece that won't show--such as the bottom or back. Another is to use a piece of scrap wood for a tester. Because each stain produces a distinctive look on different types of wood, it's crucial to use a scrap from the same wood as the furniture is made.
Stir or shake stain before beginning, as heavier pigments tend to settle in the can.
If the test-piece looks blotchy when you apply stain, you might need to apply a wood conditioner first. If so, apply a liberal amount of the appropriate type of wood conditioner (water- or oil-based, depending on your stain) about 15 minutes before staining.
Apply the stain, making even strokes with a brush, rag or pad. After a few minutes, wipe off excess stain with a cloth. Leaving the stain on longer usually yields a darker color.
Once the entire piece is stained, let it dry overnight. Apply more stain if you wish to darken the wood further. As it dries, the stained finish may take on a dull look. A fresh appearance will return when finish is applied later.
Also i think you may find its not oak but Birch thats seems to be the only unfinished ones they sell.
The bubbles most likely is applying too much at one go.
lxdollarsxl is offline   Reply With Quote
Old 04-20-2006, 02:58 PM   #3
Staining problems..
I had already applied the stain when I posted this.. my husband did 1 door & it doesn't look good, I want to take it off, because it looks real thick in 1 spot. What can I do?
Old 04-20-2006, 06:43 PM   #4
Staining problems..
I think you may have to strip all off and start again.
The best way to strip the cabinets is to use a solvent based paint remover. It will work the fastest and most completely. Sanding is time consuming, messy and does not do a complete job.
If after stripping the finish you have any residual color in the wood, use a chlorine bleach to remove it. Clorox will work.
Old 04-20-2006, 07:05 PM   #5
Contractor
Staining problems..
Like Ix said.
Bleaching will raise the grain, so be prepared to sand some more.
Try applying the stain with a damp (with stain) cheesecloth. Practice on a scrap first before tackling the 'project'. Wear gloves and rub it in. A little practice and you'll get the hang of it.
Teetorbilt is offline   Reply With Quote
Old 04-22-2006, 10:36 AM   #6
Tired, Cold, and Damp
slickshift's Avatar
Staining problems..
Those won't work if you want to re-do the door
It will have to be stripped
slickshift is offline   Reply With Quote
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 02:51 PM
Are you having ice problems? Grumpy Roofing 27 02-17-2008 04:51 PM
fence problems? composite decks? maml247 Landscaping & Lawn Care 6 03-29-2007 03:10 PM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 09:43 AM
