Staining Pine T&G - Painting - DIY Chatroom Home Improvement Forum
Old 08-16-2004, 12:36 PM   #1
Rewards Points: 14
Staining pine T&G
I've refinished my basement using tongue & groove yellow pine. Looks so good I'm hesitating to stain it and mess it up. But I need to finish it. What's the best technique to ensuring a smooth consistent coloring? Should I sand it first (even though it looks like it doesn't need it)? Should I use a sanding sealer? Bottom to top? Brush or rag? Also, I'm doing two different colors. Probably a walnut for trim, and a cherry for walls. Which should I do first? Thanks for your suggestions.
handiandi is offline   Reply With Quote
Old 08-16-2004, 05:23 PM   #2
I would've finished it before installing. But now that it's in place - I would use sanding sealer (I typically wipe it on with a rag) - then sand (150-180grit) - then stain. You'll also need to check the manufacturers directions for the sanding sealer - not many of them are the same on application.
I would do the walls first and try to tape off the trim then come back and tape off the wall or vice versa It'll be difficult to keep the stain from seeping either way you do it.
hatchet is offline   Reply With Quote
Old 03-08-2008, 01:51 AM   #3
diy mike's Avatar
Post
If you're hesitant to stain the pine, maybe consider a clear sealer to protect the wood and highlight it's natural color?
diy mike is offline   Reply With Quote
Old 03-08-2008, 04:26 AM   #4
Seal before stain? How does that work out? I am curious as to the penetration of the stain.
mark942 is offline   Reply With Quote
Old 03-08-2008, 06:34 AM   #5
Tired, Cold, and Damp
slickshift's Avatar
As the original thread is 4 years old, and hatchet hasn't been on here in 2 years, I wouldn't hold my breath waiting for an answer there Mark
slickshift is offline   Reply With Quote
Old 03-08-2008, 08:21 AM   #6
Thank you slickshift..Guess I should have read the date..........After reading this post I had to ask my question.Have you ever herd of sealing wood before staining? Is there some thing being done that I am unaware of? I guess I will be reading dates of threads and posts.
Old 03-10-2008, 09:39 AM   #7
Penniless Parent/HO
Sanding sealer is especially helpful for soft woods. It allows the stain to be absorbed more evenly and prevents blotching.
Mike
mikebal is offline   Reply With Quote
Old 04-27-2008, 10:43 PM   #8
slickshift's Avatar
Originally Posted by mark942 View Post
...Have you ever herd of sealing wood before staining? Is there some thing being done that I am unaware of?...
Yes
Using a sanding sealer is common
I don't use/care for it myself
I will use a conditioner before staining if needed though
Can't find studs behind knotty pine paneling David S General DIY Discussions 15 09-05-2010 06:56 PM
pine ceiling with T&G mark u Remodeling 17 09-27-2007 10:46 AM
Staining a garage floor? Ledge General DIY Discussions 5 07-10-2007 04:57 PM
wide pine flooring restoration lgarbacz Flooring 1 09-28-2006 01:55 PM
