-   -   Staining pine T&G (http://www.diychatroom.com/f4/staining-pine-t-g-196/)
handiandi 08-16-2004 12:36 PM
Staining pine T&G
I've refinished my basement using tongue & groove yellow pine. Looks so good I'm hesitating to stain it and mess it up. But I need to finish it. What's the best technique to ensuring a smooth consistent coloring? Should I sand it first (even though it looks like it doesn't need it)? Should I use a sanding sealer? Bottom to top? Brush or rag? Also, I'm doing two different colors. Probably a walnut for trim, and a cherry for walls. Which should I do first? Thanks for your suggestions.
hatchet 08-16-2004 05:23 PM
I would've finished it before installing. But now that it's in place - I would use sanding sealer (I typically wipe it on with a rag) - then sand (150-180grit) - then stain. You'll also need to check the manufacturers directions for the sanding sealer - not many of them are the same on application.
I would do the walls first and try to tape off the trim then come back and tape off the wall or vice versa :) It'll be difficult to keep the stain from seeping either way you do it.
diy mike 03-08-2008 01:51 AM
If you're hesitant to stain the pine, maybe consider a clear sealer to protect the wood and highlight it's natural color?
mark942 03-08-2008 04:26 AM
Seal before stain? How does that work out? I am curious as to the penetration of the stain.
slickshift 03-08-2008 06:34 AM
As the original thread is 4 years old, and hatchet hasn't been on here in 2 years, I wouldn't hold my breath waiting for an answer there Mark
:wink:
mark942 03-08-2008 08:21 AM
Thank you slickshift..Guess I should have read the date..........After reading this post I had to ask my question.Have you ever herd of sealing wood before staining? Is there some thing being done that I am unaware of? I guess I will be reading dates of threads and posts.
mikebal 03-10-2008 09:39 AM
Sanding sealer is especially helpful for soft woods. It allows the stain to be absorbed more evenly and prevents blotching.
Mike
slickshift 04-27-2008 10:43 PM
Originally Posted by mark942 (Post 105452)
...Have you ever herd of sealing wood before staining? Is there some thing being done that I am unaware of?...
Yes
Using a sanding sealer is common
I don't use/care for it myself
I will use a conditioner before staining if needed though
