Staining A Patch On Hollow Door - Painting - DIY Chatroom Home Improvement Forum
Old 12-23-2011, 08:32 AM   #1
Staining a patch on hollow door
I repaired a hole in a hollow door using a wire drywall repair patch and covering with spackle. When I applied stain to the door, I ended up with a dark area where the repair was done. While it looks better than a hole in the door, I would like to not have the repair be so visible. I am thinking of putting primer on the whole door before applying stain, but not sure if this can be done or what would be a good fix. Any ideas?
bryman63 is offline   Reply With Quote
Old 12-23-2011, 09:00 AM   #2
the Musigician
DangerMouse's Avatar
Hi and welcome to the forum.
Your post is confusing, stain will not penetrate primer. If you mean to paint it, or use solid stain, then primer should help hide what you describe.
DM
Old 12-23-2011, 10:37 AM   #3
Too Short? Cut it Again!
Might try a solid gel stain. Prime and paint. You might try a wood graining faux finish tool. You apply the base color than a darker color over it when dry. Run the graining tool through the top coat before it dries.
Old 12-23-2011, 11:24 AM   #4
Rubbin walls since'79
Brushjockey's Avatar
Just so you know- at this point you are doing a faux wood grain job. Google that or look in You tube to get ideas.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 12-23-2011, 11:44 AM   #5
I might try the gel stain. I want to keep stain on the door if possible but want the patched area to blend in with the rest of the door and not be darker. In my thinking I have to put something on the spackle that I used to repair so that the stain doesn't 'bleed' into it when applied. I think the gel stain would do that. If anyone has other suggestions, they would be welcome.
Old 12-23-2011, 12:13 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
DangerMouse I just want you to be aware of the fact that I am resisting. It is taking everything I have but I am resisting.
XXX
Old 12-23-2011, 12:26 PM   #7
the Musigician
We know Bud, and we're all very proud of you..... now go see Nurse Happypiller and she'll give you your medication.
DM
Old 12-23-2011, 01:42 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Okay great, just as long as you know!
Oh-oh...I feel another urge to comment so I'm gonna go now before it's too late.
XXX
Old 12-23-2011, 02:28 PM   #9
the Musigician
"Nurse Happypiller to room 13 please, Nurse Happypiller, room 13."
DM
Old 12-23-2011, 02:38 PM   #10
Rewards Points: 13,270
Ok I'll do it then.
Completly the wrong way to try and fix this.
A whole new door would have cost about $20.00 and it would look far better.
Drywall compound was never meant to be stained and I see no way it's ever going to not stick out.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
Bud Cline (12-23-2011), jsheridan (12-23-2011)
Old 12-23-2011, 03:18 PM   #11
I fear the OP may not be using anything with the stability of drywall compound. He said he used spackle---that light airy stuff good for absolutely nothing but filling tiny pinholes.
Old 12-23-2011, 06:22 PM   #12
Originally Posted by joecaption View Post
Ok I'll do it then.
Agree. The door will never look right. Even with painting it, the patch will still be noticeable. I would replace the door also.
hollow or solid core door for pocket door RobertN Building & Construction 4 10-12-2015 08:55 PM
Need to replace front door, existing door non-standard size uncle Windows and Doors 1 07-25-2011 07:50 AM
Security screen door dangerp Carpentry 4 09-22-2010 08:02 PM
Why can't I cut hollow core interior door with circular saw? Brandnewruins Carpentry 10 07-16-2009 03:56 PM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 04:01 AM
