Staining And Painting Window Grids - Painting - DIY Chatroom Home Improvement Forum
Old 10-17-2005, 08:23 PM   #1
staining and painting window grids
Is it possible to stain the interior of a wood window grid and paint the exterior to match white vinyl without bleed?
Thanks,
Dave
daveirwin is offline   Reply With Quote
Old 10-23-2005, 05:40 PM   #2
Yes Master
MasterStrokes's Avatar
Yes it is. I’d recommend paying for a good quality professional brush and using professional grade paints or you’ll end up having a terrible time. Sand all the little edges where the paint will meet the stain to remove wood burs. Set up a clean work area and try not to lay them flat on the floor. Stain and urethane first, then prime and paint the other side. Try not to use tape. Paints will probably get underneath it. Remember quality paint! They’re going to be exposed to a lot of temperature changes and the sun.
Edit: Personally I’d use oil based stain, urethane and paints to do these. I’d most likely give them three coats of finish products with a gloss sheen after stain and priming. I’d also do them with a good ox hair, or ox bristle brush. You might have a time finding these brushes but they’re a gem when applying oil products. Take good care of the brush or it’ll haunt you.
Edit # 2: Why oh why did you get me thinking about these window inserts? :p The finish clear gloss put on over the stain should be something like “Helmsman Spar Urethane” or a qood quality marine varnish. Look into products made by “Sikkens” and “Cabot.”
MasterStrokes is offline   Reply With Quote
Old 10-24-2005, 12:13 AM   #3
Tired, Cold, and Damp
slickshift's Avatar
I would agree
Especially about the good brushes, the quality paint/stain, and not using tape
slickshift is offline   Reply With Quote
Old 04-12-2015, 03:05 PM   #4
Rewards Points: 6
I did this last Summer in my garage. I am pleased with the results.
See this thread for an informative video:
How to: Stain and Paint window grid/ grille - DIY
genuser is offline   Reply With Quote
Hardi plank - staining vs painting acdrey Building & Construction 36 03-22-2015 11:53 AM
Staining or Painting a New Fiberglass Door MelindaA Painting 1 12-31-2005 10:37 PM
