Staining Or Painting A New Fiberglass Door - Painting - DIY Chatroom Home Improvement Forum
Old 12-22-2005, 12:06 AM   #1
Staining or Painting a New Fiberglass Door
I just had a new exterior fiberglass door installed in my home. Should I stain it or can I prime and paint it? I have never stained before. If I can prime and paint it, then what kind of primer should I use and what type of paint? semi- gloss or satin? oil based or water based? Any suggestions are appreciated.
Thank you for your help.
Melinda
MelindaA is offline   Reply With Quote
Old 12-31-2005, 09:37 PM   #2
Is it a woodgrained door? If so you can stain with a gel stain and wipe down so the stain just stays in the embossed pores then poly. To paint; sand, the door down first to give the paint something to bite to. Porter Paint makes a great acrylic bonding primer (#515), then two topcoats of a good acrylic exterior paint. The choice of sheen is up to you, just scuff sand between coats.
Kennedy is offline   Reply With Quote
Fiberglass door kjbfamily Painting 8 06-26-2007 12:44 AM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 08:43 AM
fiberglass entry door adog Building & Construction 5 11-30-2006 10:11 AM
Exterior Door Painting vs. Stain paradis42 General DIY Discussions 1 11-12-2005 10:57 AM
Help with painting an interior door Kim Painting 2 03-05-2005 12:38 AM
