Staining New Cabinets. - Painting - DIY Chatroom Home Improvement Forum
Old 05-29-2009, 07:29 AM   #1
Staining new cabinets.
Okay all you pros, guide me through this please. I have some left over stain from my upstairs when I built my house 4 yrs ago. Am now installing a vanity in my basement bathroom. I am going to use the same stain for this project.
Can someone give me guidance. I know i have to
1. Stain
2. Seal it (urethane)
3. ???
I dont need to sand it, do I?? Can I seal it with a brush on type urethane?
Thanks people
luweee is offline   Reply With Quote
Old 05-29-2009, 11:38 AM   #2
Remodeling Contractor
If the wood is a soft wood you will need to apply a pre-conditioner first to avoid the stain from blotching. Then stain. No sanding after. apply a sealer, sand lightly to scuff the surface with 220 grit paper. Then apply two coats of poly top coat sanding in between coats.
Old 05-29-2009, 12:39 PM   #3
Thanks BOB
here are some specifics.
I had these cabinets made professionally.
They are oak.
They are already sanded and ready for stain.
My sanding question was.
after i apply urethane
do I need to sand. then apply again?
220 grit? (if sanding required)
Old 05-29-2009, 04:06 PM   #4
urethane needs a stain then sealer then sanding then urethane then sanding then urethane. Oak will not need a pre-conditioner. Also the stain is optional.
Staining Cabinets??? HELP Netta Remodeling 5 03-06-2009 04:16 PM
Staining cabinets that have been stained 2 different colors? digexpressions Painting 6 07-26-2008 12:42 AM
Installing kitchen wall cabinets higher than spec recommendation? alexz General DIY Discussions 14 07-20-2008 11:32 PM
How are the premade HD and Lowes Cabinets? twilightcall Carpentry 10 05-25-2008 10:23 AM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 03:21 PM
